All items located in Campbelltown, Sydney
Stuff for sale:
Sr20 flywheel. Would need machining. I have 2 of these $60 each
Greddy type r bov -Big BOV for big boost $220
R33 fmic kit. Complete kit with 600x300x80 core, and all piping. $300
330mm big brake kit suit S13/14/15/R32/33/34 etc. Comes with alloy hat vented disks, adapters and Z32 calipers. Calipers have been sitting for a while so i'd recommend a seal kit for them. Disks are in excellent condition. Pads not included - $650
Silvia frp Vented bonnet. Dmax style. Unused. Still in white gelcoat
$450
R34 smic $100
Profec e01 Boost controller. Complete kit
$450
Hks gauges x 4 - 60mm oil temp, oil pressure, water temp and boost. Including all sensors. Loom for Boost guage is missing
$450 for the 4
Sr highmount manifold. Suit T3 flange turbo and 4 bolt wastegate flange. Never used. Bought from JustJap for $499. Identical to this one http://justjap.com/store/product.php?productid=16654&cat=252&page=4
$330
Buddy club P1 rims - 17x9 (+27) all round. Extremely light. Some small rash but nothing major. Tyres might be ok for skids. - $950
Desmond Jap rims. 17x8, 17x9 (+35 all round). Good condition. Have 2 tyres on rear 255's. Good amount of dish $750
Desmond Jap rims - 17x8 (+35) all round. Rough painted matt black. Would need a repaint. Nice dish though. One has a dent that needs to be knocked out. Exact same model as the ones above (Just not as good condition). $400 set
Various Greddy Electronic gauges - Exh Temp $150, Oil Pressure $120, Temp $120. All come with looms and sensors
Tial wastegate - 38mm. Gate only. $185
HKS 2835 minus exh housing. 52 trim. No shaft play. one exhaust blade is slightly bent so either needs to be re-profiled or balanced or something. $300
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
