hi all
curious if any of the people that already have bought this product are on these forums. If you are, would love some feedback on them. They are significantly cheaper then samco's version, and still come with warrenty too.
RB26 silicon intake piping
https://www.sau.com.au/forums/topic/370434-silicon-gtr-rb26-intake-piping/
Considering I've had Samco water hoses fail on 3 occasions, i highly doubt these would be any better :)
Factory is always best if you can get it/have it.
I am aware of R34gtt factory rubber intake piping "closing up" under high boost, are bnr34 rubber intake piping different in construction or otherwise and hence wont suffer from being "sucked in" under high boost environments? ie 1-1.2 bar on aftermarket turbos
I'm using the hks-copy hardpipe intake kit you can get off eBay USA for around $270usd. My mechanic spent a number of hours fitting it, had to modify a bit so its not a TRUE Bolton kit, cost me a few hundred in his time to modify to fit correctly. Pretty happy with how it has turned out, and doesn't invoke turbo shuffle at this stage (n1 turbo rebuild kit, running-in tune). For an rb25 I guess the silicone intake would be ok (my rb25 has the metal intake kit from performance wise sau trader) but I wouldn't want to personally use the silicone intake on rb26 engines, but that's my opinion.
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
