Lightened Flywheels, worth it?
97 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
In brief, either my spigot bush or thrust bearing is dying (horrible noises when the clutch is disengaged), so i'm changing my clutch. Already have an Exedy heavy duty clutch kit with new thrust bearing, and got a new rear main, spigot bush and input shaft seal to put in while the gearbox is out.
I've been doing alot of reading:
http://www.skylinesa...is-it-worth-it/
http://www.skylinesa...tened-flywheel/
http://www.skylinesa...ened-flywheels/
(to name a few)
And there are alot of mixed opinions about whether or not a lightened flywheel is worth it. So put together this poll in simple yes/no/unsure style. I can easily get the standard flywheel machined, but I can also get a Nismo Chromoly lightened one at a very good price, and brand new.
My car is %100 daily driver at the moment, but once it's up to a "reliable" spec, and the budget allows, I intend to have a go at drag racing, and eventually (long term) some track work.
Keeping in mind it's DE+T, so the low end response is already pretty good already, but still looking to improve.
All opinions appreciated, and hopefully anyone looking at this in the future can benefit from it. thumbsup.gif
https://www.sau.com.au/forums/topic/370436-lightened-flywheels-worth-it/
Yes it is worth it. A CroMo one will be about 1kg lighter and will fell like it gives 200-300rpm earlier boost threshold. That's pretty good, for the cost.
Lightened flyweheels, as in flywheels that have been machined down to remove weight, should be avoided whenever there is an option to buy a brand new lightweight flywheel. Alloy flywheels seem to offer a mixture of real lightness and shocking chance of crapping out. Especially that useless brand that starts with an F.
Also depends on clutch. If you get a twin plate, don't get a lightened flywheel for a daily driver.
It'll make it nicer to actually use.
Didn't get a twin-plate for that reason, just a slightly better Exedy item over the factory one.
I read that due to the low compression DET engine, take-off and low speed driving can be a p.i.t.a. But figured for a N/A it should be manageable with a reasonable clutch. Drove a GTR with a twin-plate clutch and was not a fan, not for a daily any way.
I have a 4 or 4.5 kg flywheel in my nearly standard GTS-t. Didn't really notice any difference on hills, low speed driving or take-off. If anything it decreased NVH when bogging down the engine.
Engine does seem a lot more responsive when rev matching though :)
I'm happy enough With my NPC Flywheel
Billet with cooling vents in the centre for my NPC single plate button. It was more a piece of mind thing for me over anything else. Im not really chucking out the power to be throwing flywheels around but nice to have a new one, and know that at least im getting some cool air to the centre of the clutch.
Rev wise, its a bit more responsive but not a great deal that I can tell..... Mine weighs 6.6kg, been meaning to weigh the stock flywheel, has anyone got a weight for it? Dont think its much heavier but
If you don't mind me asking, what did you pay for it? Or was it part of a kit?
Do you believe it was good value for money in terms of response/feel etc, or would you "not do it again" sort of thing?
  • 3 months later...
Shaft me sideways! If you want easy driving get a Auto FFS! :laugh:
I've got an Exedy twin plate with the lighter flywheel that came with it, it takes some skill to drive but it just revs so much more responsively with the lighter mass. The heavy fly wheels make cars feel like slugs in comparison.
+1 for the NPC steel billet lightened flywheel (6.8kg)
I reckon it is magic! The engine is much more responsive; quicker to rev, easier to rev match on down shift and better to drive all around!
TBH I haven't noticed any down side to it at all; motorway, carpark, around town and through the hills it is all good.
If you have to replace the clutch anyway it is an option that is well worth considering...
For less than the price of a Jim Berry full monty I got a clutch (10" HD Organic; good for 300+rwkw) and flywheel from NPC!
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
