Lightened Flywheels, worth it?
97 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
In brief, either my spigot bush or thrust bearing is dying (horrible noises when the clutch is disengaged), so i'm changing my clutch. Already have an Exedy heavy duty clutch kit with new thrust bearing, and got a new rear main, spigot bush and input shaft seal to put in while the gearbox is out.
I've been doing alot of reading:
http://www.skylinesa...is-it-worth-it/
http://www.skylinesa...tened-flywheel/
http://www.skylinesa...ened-flywheels/
(to name a few)
And there are alot of mixed opinions about whether or not a lightened flywheel is worth it. So put together this poll in simple yes/no/unsure style. I can easily get the standard flywheel machined, but I can also get a Nismo Chromoly lightened one at a very good price, and brand new.
My car is %100 daily driver at the moment, but once it's up to a "reliable" spec, and the budget allows, I intend to have a go at drag racing, and eventually (long term) some track work.
Keeping in mind it's DE+T, so the low end response is already pretty good already, but still looking to improve.
All opinions appreciated, and hopefully anyone looking at this in the future can benefit from it. thumbsup.gif
https://www.sau.com.au/forums/topic/370436-lightened-flywheels-worth-it/
Yes it is worth it. A CroMo one will be about 1kg lighter and will fell like it gives 200-300rpm earlier boost threshold. That's pretty good, for the cost.
Lightened flyweheels, as in flywheels that have been machined down to remove weight, should be avoided whenever there is an option to buy a brand new lightweight flywheel. Alloy flywheels seem to offer a mixture of real lightness and shocking chance of crapping out. Especially that useless brand that starts with an F.
Also depends on clutch. If you get a twin plate, don't get a lightened flywheel for a daily driver.
It'll make it nicer to actually use.
Didn't get a twin-plate for that reason, just a slightly better Exedy item over the factory one.
I read that due to the low compression DET engine, take-off and low speed driving can be a p.i.t.a. But figured for a N/A it should be manageable with a reasonable clutch. Drove a GTR with a twin-plate clutch and was not a fan, not for a daily any way.
I have a 4 or 4.5 kg flywheel in my nearly standard GTS-t. Didn't really notice any difference on hills, low speed driving or take-off. If anything it decreased NVH when bogging down the engine.
Engine does seem a lot more responsive when rev matching though :)
I'm happy enough With my NPC Flywheel
Billet with cooling vents in the centre for my NPC single plate button. It was more a piece of mind thing for me over anything else. Im not really chucking out the power to be throwing flywheels around but nice to have a new one, and know that at least im getting some cool air to the centre of the clutch.
Rev wise, its a bit more responsive but not a great deal that I can tell..... Mine weighs 6.6kg, been meaning to weigh the stock flywheel, has anyone got a weight for it? Dont think its much heavier but
If you don't mind me asking, what did you pay for it? Or was it part of a kit?
Do you believe it was good value for money in terms of response/feel etc, or would you "not do it again" sort of thing?
  • 3 months later...
Shaft me sideways! If you want easy driving get a Auto FFS! :laugh:
I've got an Exedy twin plate with the lighter flywheel that came with it, it takes some skill to drive but it just revs so much more responsively with the lighter mass. The heavy fly wheels make cars feel like slugs in comparison.
+1 for the NPC steel billet lightened flywheel (6.8kg)
I reckon it is magic! The engine is much more responsive; quicker to rev, easier to rev match on down shift and better to drive all around!
TBH I haven't noticed any down side to it at all; motorway, carpark, around town and through the hills it is all good.
If you have to replace the clutch anyway it is an option that is well worth considering...
For less than the price of a Jim Berry full monty I got a clutch (10" HD Organic; good for 300+rwkw) and flywheel from NPC!
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
