Hi guys, Im thinking of putting on a nistune on my r34gtt... Mods are: full exhaust, fmic, walbro fuel pump, greddy ebc 10 psi, all the basic mods... How much wil it costs me?? And a good place to install nistunes?? Im from the west btw.. Cheers
https://www.sau.com.au/forums/topic/370474-nistunes/#findComment-5905731
if you can grab a lift over, you can leave it the night before and then pick it up the following arvo. It's not that far a walk from dandy station, and i'm sure there is a bus that goes closer.
i would "think" they would only need 1 day to get it done, so you could prob just hang around whilst it's done if you've got a free day somewhere
Best to ask them though.
https://www.sau.com.au/forums/topic/370474-nistunes/#findComment-5905967
Thank you for your kind help.. I will give them a buzz tomorrow..
https://www.sau.com.au/forums/topic/370474-nistunes/#findComment-5905973
Yes charles, you're right... But ill give chasers ago... Been their customer before, i think they will do the job right... Well, its time to find out next week.. Cheers to everyone .. Been really helpful...!! I will update the results..
https://www.sau.com.au/forums/topic/370474-nistunes/#findComment-5906117
Oh yeah, no doubt, Chasers, Dr Drift & Chequered Tuning are all reputatable, so any one of those should be just fine.
And yeah, let me know your results, coz I wanna get mine done too :P
No probs.. I saw u selling ur nistunes daugtherboard, why dnt u used it?? I actually txt u for ur power fc and askd u bout the wing stays as well yesterday... :)
https://www.sau.com.au/forums/topic/370474-nistunes/#findComment-5906158
Oh haha xD
Yeah I sold my board, because I got the board as a payment for a job that I did for someone, and I think Chequered wanted $50 to install and $650 for a tune, so it woulda cost me $700. Where as, when I sold the board for $250, I only need to add $600 on top for a drive in drive out deal at Chequered for $850 :)
https://www.sau.com.au/forums/topic/370474-nistunes/#findComment-5906166
Oh haha xD
Nice... :)
https://www.sau.com.au/forums/topic/370474-nistunes/#findComment-5906214
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
