Hi guys, Im thinking of putting on a nistune on my r34gtt... Mods are: full exhaust, fmic, walbro fuel pump, greddy ebc 10 psi, all the basic mods... How much wil it costs me?? And a good place to install nistunes?? Im from the west btw.. Cheers
https://www.sau.com.au/forums/topic/370474-nistunes/#findComment-5905731
if you can grab a lift over, you can leave it the night before and then pick it up the following arvo. It's not that far a walk from dandy station, and i'm sure there is a bus that goes closer.
i would "think" they would only need 1 day to get it done, so you could prob just hang around whilst it's done if you've got a free day somewhere
Best to ask them though.
https://www.sau.com.au/forums/topic/370474-nistunes/#findComment-5905967
Thank you for your kind help.. I will give them a buzz tomorrow..
https://www.sau.com.au/forums/topic/370474-nistunes/#findComment-5905973
Yes charles, you're right... But ill give chasers ago... Been their customer before, i think they will do the job right... Well, its time to find out next week.. Cheers to everyone .. Been really helpful...!! I will update the results..
https://www.sau.com.au/forums/topic/370474-nistunes/#findComment-5906117
Oh yeah, no doubt, Chasers, Dr Drift & Chequered Tuning are all reputatable, so any one of those should be just fine.
And yeah, let me know your results, coz I wanna get mine done too :P
No probs.. I saw u selling ur nistunes daugtherboard, why dnt u used it?? I actually txt u for ur power fc and askd u bout the wing stays as well yesterday... :)
https://www.sau.com.au/forums/topic/370474-nistunes/#findComment-5906158
Oh haha xD
Yeah I sold my board, because I got the board as a payment for a job that I did for someone, and I think Chequered wanted $50 to install and $650 for a tune, so it woulda cost me $700. Where as, when I sold the board for $250, I only need to add $600 on top for a drive in drive out deal at Chequered for $850 :)
https://www.sau.com.au/forums/topic/370474-nistunes/#findComment-5906166
Oh haha xD
Nice... :)
https://www.sau.com.au/forums/topic/370474-nistunes/#findComment-5906214
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
