Hey guys,
i have asked a few mates about o2 sensor, some of them said runs fine without one. I have run my sr over half a year now since i have a new engine drop in and what i found out is that the workshop that did the engine conversion didnt install the o2 sensor for me. what i saw is they blocked the o2 sensor hole with some washer or something like that, i having difficulties of starting the car every morning, i called them up and they said was the fuel pump too big and need the regulator... help me guys...
cheers
https://www.sau.com.au/forums/topic/370483-omg-o2-sensor/
Yeh my o2 sensor isn't connected in my car, runs fine without it. The car 'surges' a bit when cold and in closed loop, but fine other than that.
As for the fuel reg, they are a waste of money. Completely unnecessary if you have correct size injectors.
https://www.sau.com.au/forums/topic/370483-omg-o2-sensor/#findComment-5905804
That's aftermarket fuel regs, not the standard one.
Yeh that's what I meant.
Personally if it's a street car than I'd have the 02 Sensor working, as closed loop control will give you much better fuel economy.
Depends how it's tuned. If it is tuned properly around cruise then you may get better fuel economy. I get 600kms to a tank if I drive nicely, 550ish if I drive around on boost a lot.
https://www.sau.com.au/forums/topic/370483-omg-o2-sensor/#findComment-5906434
i get 350 to a tank, maybe need to turn one turbo off :laugh:
https://www.sau.com.au/forums/topic/370483-omg-o2-sensor/#findComment-5906813
So other than the surging its all good ? :whistling:
https://www.sau.com.au/forums/topic/370483-omg-o2-sensor/#findComment-5907113
so you guys mean running without o2 sensor doesnt really matter? then i have to look at my fuel pump, i dont have an aftermarket fuel regulator which makes the cold start really hard.... crank a few times before start... i surprised that honaldo runs 550-600 for a tank... mine only runs 350-400 for a tank with running stock boost 6-7 psi. ALso my carblowing smokes when i hit boost... wtf? you guys recon my turbo is weak now?
https://www.sau.com.au/forums/topic/370483-omg-o2-sensor/#findComment-5907117
Well as far as I can associate with the O2 sensor yes... Car has gremlins, I'm missing about 100rwhp and 500rpm of response, but can't see that relating to the o2 sensor. Still searching for an answer to that problem. I also get a lot of reverberation, but again that is to be expected having an AFM in front of a big turbo.
As for the 'surging', that doesn't really describe it. It's not like a fuel surge you get from running low on fuel. It's like when I'm cruising on decel, using the engine speed to maintain roadspeed going down a hill or something like that, it sort of feels like I'm tapping the brake slightly and then taking it off. It slows down a tiny bit then picks back up. If I touch the accelerator at all then it doesn't do it. Given it only does it when cold, I imagine it is sensor related. Can only think of either TPS or o2 sensor, and seeing as my o2 sensor is unplugged then it makes sense.
/long winded explanation :P
https://www.sau.com.au/forums/topic/370483-omg-o2-sensor/#findComment-5909535
    • We are literally just kids stuck in an adult's body with bills and mortgages to pay 🥲
    • Behrman is great quality stuff. My 34 has some serious clouding as well but I’m too nervous to try and replace the glass myself so I haven’t bought them yet.
    • This might be true if you live in NZ but I can't see how this could be true for us locals here.  I've found the customer support for Haltech to be absolutely amazing. I've turned up to Haltech and spent entire days with their tech support guys, they've even helped me with wiring dramas that had nothing to do with their products.  They have the best customer support of any company I've dealt with, I can't imagine how my experiences with them could possibly be any better.
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
