R32 GTR 1991
Selling for a friend. Matt can be contacted on 0411 781 741
Regrettable Sale - New P Plate Laws. im not allowed to drive a turbo car anymore
Makes a really responsive and Reliable 270Rwkw on very safe tune running 18Psi. I had -5's and didnt like the lag.
Car made 320rwkw with then running 18Psi but it feels almost faster now having so much more time in boost.
will easily make more power with more boost, air flow meters amd cams.
GT-C Volk 18x9's all round with custom GTR offset
Built Motor (done about 2,000 k's since build)
Chemical clean all parts, full machine,clearance and blueprint spec, ACL comp bearings, JE forged piston kit, H-beam rods,
MLSR steel head gasket, oil restrictors, genuine nissan gasket set, tensioners, Recon head, complete assembled from sump to rocker covers.
all new hoses
new genuine thermostat
new water pump
new timing belt
nismo radiator cap
new battery
new heater core
regassed Air conditioner
nismo diff bushes
cradle spacers (pineapples)
600cc injectors
nismo plugs
Garret 28/60 -7's
Apexi Power FC with Hand Controller
Full 3" Kakimoto Exhaust
Blitz 4stage Boost Controller
R33 GTR Crank
N1 Oil Pump
Momo Steering Wheel + Gear Knob
'Top Secret' Carbon Fiber Dash/Console Surround
Custom Leather Interior
Tomei 310km/h Dash Cluster
New slotted rotors all round (DBA)
Extreme heavy duty motor sport clutch
Koyorad radiator
custom buzzer/Warning light (oil pressure, coolant level, water temp.) better then trying to watch gauges whilst driving.
Central Locking/Alarm
Good stereo (alpine headunit, Focal Splits and rears, Basic sub/amp setup)
Baffled sump
Bosch fuel pump
Always has run fully synthetic oil
Always kept off the limiter
Never been launched
Brand new tires
Im sure there is things I have missed. Photos do not do the car justice.
Car owes me 50k. have receipts for the last 15k spent a month ago
regrettable sale, but i cant legally drive it for the next 2 years
Im after 25k ONO and im aware im asking a high price but its one of the best 32 GTR's in SA.
Has been featured in HPI.
The other option is 22k ONO bring your own wheels and i keep the carbon dash, sub and cd player.
There's other 32 GTR's on the forums for 20-22 but they arn't forged motors, nor do they have amazing wheels or interiors. Priced to go.
If your not interested in buying or giving positive comments don't post, don't send me a PM as im not on the forum often, do text or call me. Thank you.
Edited by SNIPER32
https://www.sau.com.au/forums/topic/370504-1991-r32-gtr-sniper-mint-condition/
Still for sale, only dreamers with no money at this stage. I can see there is cheaper 32 GTR's on the forums making similar power but no forged motors, no amazing wheels, no mad interior. This car is the complete package. Buyer will be as happy to own it as i have been. :whistling:
All the required oil issues have been solved with oil restrictors etc when it was built, Most 32's have issues with oil pump and crank, thus both got upgraded.
Try and sell ya cars guys. Keen to sell it asap. Inspections welcome. :) Will not disappoint :banana:
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
