Hey, when I try to fold in the drivers side mirror in the passengers mirror folds in, also when the switch is in the middle (no mirror is selected) the passenger side mirror folds in!!!
I have check the fuse 2nd from the bottom right (10amp) under the steeling wheel and it looked fine.
Any suggestions?
I know there are tutorials here, but none are for fixing this problem.
Edited by H4x
https://www.sau.com.au/forums/topic/370512-broken-mirror/
I believe that switch controls adjusting the mirrors, not folding them in or out.
you are correct. the left/right switch is for when you want to adjust the mirrors. the fold in switch is independant of that and will fold in both mirrors at once. if it was only folding in 1 mirror then there is a fault.
https://www.sau.com.au/forums/topic/370512-broken-mirror/#findComment-5906398
