Hi Guys,
I just had my battery replaced. I did it myself.
What i did:
I went to supercheap and bought a battery branded "Century" with slightly bigger size battery(the guys said this have more power and it have no problem as long as i can fit it in) because they don't have the one exactly same with the old one i using.
And i went back home then replace my battery, it was pretty quick. After that, yay! my engine started but then i realize i can't turn on my stereo system(radio) , there is no power on stereo. Also the batter light is ON on the dashboard.
I then went back to supercheap and get another guy to check what is wrong with it, he took out a Century battery meter(tester) and then test my car. When he ready he asked me to start my car and then the meter read 10.5V(around) and he told me it has to be minimum 13.X v . Rev the engine won't raise the V too. Then he told me that my "Alternator" is broken and need a replacement for that.
He said the Alternator won't charge the battery anymore that is why it stay at 10.5v and he asked me to drive back home asap and then find a mechanic to replace my Alternator.
Is he correct?
Just want to make sure before i go and buy an Alternator from wreckers.
Thanks a lot guys.
p.s Also my car wasn't so smooth on idle. It's like close to dead, probably it's because it only have 10.5v?
Edited by MrKenny
it sounds like an alternator dead (or wiring issue) to me. you are only seeing 10v because the alternator is not working proberly or not working at all, so you are just getting the battery's voltage.
yayaya that's what the SuperCheap guy told me, and asked me to replace the Alternator. And he said it will cost a lot :( :(((
yeah it will cost a couple of hundred including remove and refit.
personally I'd recommend puting a reconditioned alternator in rather than just a second hand one.....you never know how long another second hand one will last before you need to replace it again.
do you mean ask a auto electrician to rebuild the alternator inside for me? do you know roughly how much it will cost? and i have no idea how to remove it from my car and refit it :(
yeah it's not a tricky job really...but if not confident get someone to do it for you.
Either they can rebuild the one in your car, or they can swap it for a pre-rebuilt one. Not sure on an exact cost but it will be a couple of hundred dollars.
if its a fuse issue, it wont stay at 10V right? 10V is way too low correct??
alternator has an ignition supply to excite it. without that supply it wont charge and will continue below 10v until it wont run at all. not sure if the light will be on if the fuse is blown but its easy to check fuses so start there
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
