Hi Guys,
I just had my battery replaced. I did it myself.
What i did:
I went to supercheap and bought a battery branded "Century" with slightly bigger size battery(the guys said this have more power and it have no problem as long as i can fit it in) because they don't have the one exactly same with the old one i using.
And i went back home then replace my battery, it was pretty quick. After that, yay! my engine started but then i realize i can't turn on my stereo system(radio) , there is no power on stereo. Also the batter light is ON on the dashboard.
I then went back to supercheap and get another guy to check what is wrong with it, he took out a Century battery meter(tester) and then test my car. When he ready he asked me to start my car and then the meter read 10.5V(around) and he told me it has to be minimum 13.X v . Rev the engine won't raise the V too. Then he told me that my "Alternator" is broken and need a replacement for that.
He said the Alternator won't charge the battery anymore that is why it stay at 10.5v and he asked me to drive back home asap and then find a mechanic to replace my Alternator.
Is he correct?
Just want to make sure before i go and buy an Alternator from wreckers.
Thanks a lot guys.
p.s Also my car wasn't so smooth on idle. It's like close to dead, probably it's because it only have 10.5v?
Edited by MrKenny
it sounds like an alternator dead (or wiring issue) to me. you are only seeing 10v because the alternator is not working proberly or not working at all, so you are just getting the battery's voltage.
yayaya that's what the SuperCheap guy told me, and asked me to replace the Alternator. And he said it will cost a lot :( :(((
yeah it will cost a couple of hundred including remove and refit.
personally I'd recommend puting a reconditioned alternator in rather than just a second hand one.....you never know how long another second hand one will last before you need to replace it again.
do you mean ask a auto electrician to rebuild the alternator inside for me? do you know roughly how much it will cost? and i have no idea how to remove it from my car and refit it :(
yeah it's not a tricky job really...but if not confident get someone to do it for you.
Either they can rebuild the one in your car, or they can swap it for a pre-rebuilt one. Not sure on an exact cost but it will be a couple of hundred dollars.
if its a fuse issue, it wont stay at 10V right? 10V is way too low correct??
alternator has an ignition supply to excite it. without that supply it wont charge and will continue below 10v until it wont run at all. not sure if the light will be on if the fuse is blown but its easy to check fuses so start there
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
