Hi guys,
Just selling some parts for a mate as he's just done a manual conversion on his 1999 R34 GTT, basically he just wants the parts gone so make any offers, have just set benchmark at $200 but is negotiable. Includes all parts that weren't used from converting auto to manual including interior parts.
Nismo catback exhaust with inbuilt silencer muffler $300
R34 Auto Steering Wheel
R34 Standard Centre Gauges
R34 Auto Dash Cluster, not sure how many kms on it will have to check
PM any offers or questions. If you want pics of specific parts PM and I'll get them on the weekend.
Parts located in Melbourne, sth east suburbs Braeside
Cheers
Dan
He is looking around the $300 mark for catback exhaust with Nismo muffler, but will send any offers to him to decide whether to accept.
Wats the size of the cat back?? 3"?? It looks small
Think catback is 3inch, with 4inch tip, cars being getting work done for last 6 months just starting to clear out the original parts that came on the car. I'll find out for you.
PMs replied
Edited by ShyBoi
Drivers and Passenger R34 Coupe seats also available, $100 each or $180 the pair. Local pickup in Melb preferred otherwise delivery at buyers expense.
I'll try and get pics for these also on the weekend.
Dan
Also have R34 GTT Automatic Cluster with 107,000kms on it for sale $150, PM any offers if your interested.
Also have parts off a R33:
Clutch Fan $30
Rear Seats $40
Standard Exhaust Manifold $30
Spacesaver Wheel $30
Alternator $60
Side Mirrors (Custom colour so would need to be repainted) $80 both
R34 GTT Automatic Gearbox 170,000kms $300
R34 GTT Automatic Gear Selector $50
R34 GTT Automatic Dash Cluster $120
R34 GTT Centre Gauges factory without housing (2 sets) $30 each
R34 Auto Steering Wheel back up for sale, but does not include Airbag module in the centre. So it'd be ideal for those who want a clean looking steering wheel and can transfer their airbag module from current steering wheel.
PM offers
R34 Auto Gearbox 107,000kms on it, and parts available after manual conversion was done $300 everything included from conversion except interior pieces below
Centre Console $50
R34 Standard GTT Auto Dash Cluster with from memory 107,000kms on it $120
R34 GTT Triple Gauges factory without the housing $20
Currently pending respone on:
R34 GTT Auto Gear Selector $50
R34 GTT Nismo Exhaust $250
R34 Front Seats $150 each or $200 both no rails included
R34 GTT Steering Wheel with no air bag module $80 in good condition
All PMs replied, all parts still available as people have made offers but not picked up the parts or made further contact.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
