Other parts avalable;
Stock suspension
Also stock camber arms, tie rods etc
Front strut brace will also fit r33
Front seats $100 each
Factory ECU R34 Gtt
Auto Gearbox done 80,000kms make any offers
Other parts from auto from doing transmission conversion
Steering wheel and gauges sold pending payment
Nismo exhaust sold pending payment
Gear surround and auto selector sold pending payment
Dash cluster sold
Clutch Pivot sold
Waiting on payment for gauges
Waiting on reply for exhaust
How much for the camber arms and tie rods etc? What else do you have related to that not including the shocks?
Yeh they have been posted got a receipt number if u want it, wasnt express post just normal
  • 3 weeks later...
i'll take the triple gauge set @ $20, plus postage to 5160 s.a
cheers, troy
if you still have a set that is.
Edited by rb20-into-mr30=
Gauges are sold
Steering wheel sold
Gearbox sold
Dash cluster sold
Ill find out for strut brace and pm
    • And make sure the belts are tightened appropriately too.
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
