Hey Guys,
Have the following stuff for sale. Need to clear out the garage.
R32 GTR Whiteline Adjustable Caster Rod Bushes (Brand New) - $80
R32 Whiteline/SuperPro Upper Control Arm Bushes (Non-adjustable)(Brand New) - $80
R32 Front Strut Brace (Red) - $100
R32/180sx Rear Strut Brace (Silver) - $80
RB20/25 Screamer Dump Pipe - $130
RB20/25 Front Pipe - $50
Reclinable Bucket Seat w/ R32 seat rails - $200
RB20 Alloy Radiator (Unknown condition) - $50
R200 5 bolt Welded Diff (Freshly welded) - $100
R32 steering wheel boss kit and sports steering wheel - $100
R32 GTR Rear Wing - $50
All prices are negotiable.
Items available for pick-up from Chermside, Brisbane. Otherwise delivery at buyers expense.
Cheers
Stephen
Edited by skylinegtts
https://www.sau.com.au/forums/topic/370538-bne-various-parts-have-a-look/
PM Sent gwin.
Parts left as follows:
All prices negotiable.
Price Drop !!!
R32 Front Strut Brace (Red) - $70
RB20/25 Screamer Dump Pipe - $100
RB20/25 Front Pipe - $30
RB20 Alloy Radiator (Unknown condition) - $30
R200 5 bolt Welded Diff (Freshly welded) - $70
R32 steering wheel boss kit and sports steering wheel - $70
R32 GTR Rear Wing - $30
Prices dont include postage. Will be extra, shoot me a PM for a price.
TAKE IT AWAY!!!
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
