I am selling my stagea ppls. why?? because i am working in remote NT and there is no need for the car anymore.
Anyway heres the details
2002 Nissan Stagea (M35 250t rs)
60 000kms
rego till sep 2011
MODS
Kakimoto cat-back exhaust
DBA 4000 x-drilled and slotted front rotors
RDA slotted rear rotors
QFM A1RM pads on the front
QFM HPX pads on the rear
(brake discs and rotors roughly 15 000kms old)
Pioneer head unit and rear speakers
Other info:
-the car is fitted with the factory aero kit without fog lights in front bar.
-Replaced the spark plugs with DENSO iridiums 10 000kms ago
-changed leaky left bank rocker cover seal (common prob with the M35)
-replaced CV boot right hand side outer (had others checked all seem fine)
-always change the oil and filter every 5000kms with Penrite full synth. just been done 50 k's ago
-have 8lt of nissan matic J trans fluid to come with sale (i havent got round to changing the trans fluid yet)
-factory Bilstein suspension
- also have spare AFM bought it incase mine ever crapped itself.
-the car runs very smothly never had one problem with it gets 750kms off a tank on the freeway. (little bargining info to convince the better half :thumbsup: ) paint is in perfect condition apart from the little stone chip here and there and a 20cent piece size ding above drivers wheel arch(bloody carparks with incompetent ppl) paint is not cracked so it can be easily repaired and i have factored that into the selling price. interior is immaculate except from the front speaker pods (me thinks previous owner had custom door pods but didnt want to sell them so replaced with this crapy stick on carbon fibre look alike material. not that bad you can always source some factory ones)
car looks the goods and will not disapoint.
Matt 0427 371 735
[email protected]
I am looking for 14 000 firm this is the one of the cheapest on carsales and here.
price is low to accommodate both a quick sale and ding repair. mechanically the car is perfect.
pics
and the ding
ah is it?? did you perhaps buy the nismo exhaust around july last yr?? the importer must have added the kakimoto just before i bought it!!
p.s i love the gold too just hope someone loves it enough to buy itconfused.gifconfused.gif
i know.. have a possible buyer maybe putting a deposit on tonight... fingers crossed..
its tuff times for the stagea's.. I thought there was a market for AWD wagons in aus i was obviously wrong!!
Might i also add the genuine "NURBURGRING" badge/sticker on the back from my mates trip to the burger-ring may become somewhat of a collectors item if the ring doesnt get saved which im sure some company will.. anyway it has to add some valuetongue.giftongue.gif
Edited by matty_M35
  • 3 months later...
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
