hi guys
selling a head unit and speakers which have had very limited use.
JVC SHX855 head unit - $175
Pioneer TS-E1695 3-way speakers - $125
both in very good condition and comes with head unit manual, face cover and remote. I have the receipt floating around somewhere......was around $780 for the head unit and $250 for the speakers.
Head unit features...
256 Colour OEL Display
Digital Amp
Advanced DSP (Digital 9-band iEQ, 3-Band Parametric iEQ, LPF/HPF Crossover, Time Alignment)
SD Playback
SD PICT
CC Converter
70W x 4 Max.
Shock Proof Memory
DiAS Digital Tuner
BBE Digital High-Definition Sound
MP3/WMA Compatible
Advanced Multi-Bit DAC
5V Line Output Level
5V Subwoofer Output Level
Gold-Plated Line Output Terminals (x 2 pairs)
Gold-Plated Subwoofer Output Terminals
Gold-Plated Adjustable Line Input Terminals
Motorized Slide-Out Face
Steering Remote Control Ready
CD Player
MP3/WMA Compatible
ID3 Tag/WMA Tag
Shock Proof Memory
CD-R/RW Compatible
CD Text
Disc Name Registration
Direct Track Access (1-12) (Remote Control Only)
Random/Repeat Play
Intro Scan
CD Changer Control
MP3 Control*
CD Text*
Direct Disc Select (1-12) (Remote Control Only)
Random/Repeat Play (2 modes)
Intro Scan (2 modes)
* In conjunction with CH-X1500. SD
Tuner
DiAS Digital Tuner
6 AM 18 FM Presets
Station Name Registration
SSM (for FM)
Seek (Up/Down)
Stereo/Mono Switch (for FM)
Auto Antenna
Amplifier Section
280W (70W x 4) Maximum Power Output
39W x 4 RMS Power Output
80 dBA Signal to Noise Ratio
Digital Amp
CC Converter
BBE Digital
Source-Specific Volume Control
Balance/Fader Control
DSP
9-Band iEQ
Time Alignment
LPF/HPF Crossover
Adjustable Line Input with Gold Plated Terminals
5V Line Output Level with Gold Plated Terminals
Line Output Terminals (2x Pair) with Gold Plated Terminals
Subwoofer Output with Level/Frequency Control with Gold Plated Terminals
Max. Amp Gain Switcher
Amp Defeat Switch
Display
SD PICT* with Image Converter
256-Color OEL Display
Level Meter
Switchable Dimmer (Time)
Power Switch Standby Illumination
General
Detachable Control Panel with Carrying Case
Beep Tone Support
Multi-Function Wireless Remote Control
COMPU PLAY
Tel. Mute
Rotary Encoder
Power-Off Mode Eject
Speaker features...
Features TS-E1695
Maximum output power 220 Watt
Nominal output power 60 Watt
Frequency response 30 - 32.000 Hz
Lowest resonance frequency (Hz) 62 Hz
Sensitivity (1W/1m) 91 dB
Woofer size (cm) 16 cm
Woofer material 3D Magnesium Hybrid
Tweeter size (mm) 10,0 mm
Midrange size (mm) 30,0 mm
Midrange material Titanium dome
