Mercedes/Eaton Supercharger M45
came off a low km Mini (5000km ish from what i was told) and upgraded to turbo
as new condition
no lobe marks or scratches on the teflon coating
spins freely
has stock 7psi pully
early boost of around 3-4psi from idle (depending on crank pully)
can throw in my old set up for this S/C for whooper meal 4G63 (not direct bolt on but you get the idea how to make your own kit)
will suit anything up to 2Lt
need to unload this, as i dont have anything thats a 2lt any more :P
$500 pick up in melb or i can meet you half way...
Rebuilt TD06 17C
rebuilt/new condition
bought with fairly large rear housing, will need to be changed for your application (ebay has some internal and external gated)
oil cooled
needs external (but depends on your rear end)
this needs to go as well, was paired up with my supercharger (above) for twin charge set up, but i no longer want to go this path........
both units can be viewed upon request....
Or buy both for twin-charging for $900
2" hotdog mufflers/resonators $20 each or all 4 for $70
near new, came off low km VE exhaust replaced with straight pipes
stainless steel
2" in and out
3.5" diam X 11" long
SR20DET door stop (suit rebuild!)
long block
had an oil pump go on it
doesnt seem to have scratches on the cam lobes
has rocker arm stoppers
suggest viewing the engine
$350
pm me or reply here...
cheers
Jay...
https://www.sau.com.au/forums/topic/370563-eaton-m45-td06-hotdogs/
  • 1 year later...
I have a freind who is keen on supercharger, pm me your number and I will pass it on, cheers.
Edit: they have a mini and the supercharger just went on them (teeth broken and seal let go) so they are very keen!!!
Edited by Streetbike_Tommy
