Hey Guys
Been looking at the Impul body kit (Sides and rear only) to stick on the 34 with the factory front + lip.
I have uploaded a photo of my front (Factory + lip) here: http://mezmamedia.com/richie/photos/skyline_r34/skyline_yen_mumshouse_photoshopped.jpg
I'm thinking about getting the impul side skirts and rear bumper or the bomex sides and rear bumper. I'm leaning towards impul sides and rear.
The car hasn't been lowered and the front with the lip is approx 150mm off the ground.
Anyone know the height of the side skirts from factory suspension of the impul and bomex sides?
I'm hoping the impul side skirt kits would be around the same height as the front so they line up. The impul front bumper doesn't look like it would be much lower than my factory front and lip (Going by photos anyway).
Any and all help would be appreciated :)
looking good Charles. I attempted de-badging mine on the weekend - ended up melting the paint with the hair drier :(
Richie - I was looking at the z-tune skirts for my car, I think they would go with the front lip. Then again, I am going for the clean discrete look.
Yeh thats why I am looking at the impul side and rear - It doesn't look that much different than the factory stuff (Just a bit taller etc). The side skirts look like standard R33 sides as well.
If you think that's my car, it's not :P
My R34 is much more unique than that xD
Nope, I reckon it would be similar height, because the lip slopes down from the front to the rear, so the rear of the lip is lower, which should line up with the skirts.
If you want, I took my Nismo skirts to my panel beaters yesterday, so hopefully I'll have them on my car sometime next time, I'll send you some pics, because I think the Nismo skirts is pretty similar to Impul.
That will be awesome man - Decided not to paint your skirts yourself hey :P ?
I'm keen to get the impul sides and rear for the car - Looks like a better version of the factory standard kit hehe
Just don't want funny looking cross with the skirts and front
The impul front kind of looks like the factory bar with the lip as well :|
Yeah, coz the skirts needed to be kinda re-fibreglassed in some corners lol.
I agree, the Impul kit is one of my favourite, but I only like the sides and rear, the front is a little too much for me haha.
The side is simple and the rear is like factory but with added "pods" lol, just a clean, simple kit.
It lines up pretty nicely with your front lip man... That has given me more confidence that the impul side skirts should lineup with my bar...
ps: your car is in dire need of a wash :P
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
