^^^ Nice! Did you do the angel eyes yourself? I am keen on doing it, but am still a bit apprehensive.
Yes did myself, 5000K ССFL. Baked them twice because first time left ballasts inside the headlamps and because of heat a ballast was f$cked up. Now both are out of headlamps.
Sweet. Did you use a website or videos to show you how to do it? Any tips or rticks? Where did you buy the CCFL kits? So many questions ....
I am also considering putting a pair in each rear light to run full time to give me the full hotplates look :)
I'd recommend this kit. http://cgi.ebay.com/ebaymotors/2003-04-Infiniti-G35-Sedan-Headlight-hid-HALO-Demon-Eye-/360123300970?pt=Motors_Car_Truck_Parts_Accessories&hash=item53d9057c6a
You can use a heat gun instead oven it just takes more time but it is safer. What you will have to do is take headlamp off, ballast and there are 3 little screws on the back side of each headlamp.
They look so nice, cobey we may have to talk about you lights lol, i have some angle eyes to install in my ken style front bar once its on should look good, im gona look into the polish but i think that its 90% on the inside of the light, i think they did not seal it properly after compliance when they take out the stock lights and swap the over for legal ones here.
If you follow my guide it will cost you $50 for the kit from memory (most of that is in shipping, actual halos are like $14 for a pair x2)
You will need to know the size of the halos first as if you have a sedan then its different or if you have a 06+ coupe then its different than mine..
http://www.skylinesaustralia.com/forums/topic/349829-g35-coupe-halos-diy-guide/page__p__5621678__hl__halos__fromsearch__1#entry5621678
This is the before and after of when I did my headlights fyi
Nice and shiney there, Andrew. :thumbsup: Is that "Nismo" sticker inside or outside the headlights?
For me, I drive my V35 mostly evenings on weekends when it's getting dark. But, I resist myself from turning the main headlights on until it's really necessary and instead drive with my parker lights on to reduce the chances of clouding up the inside of the headlights faster. I don't know if that works though. :P
It's on the outside mate ....
http://cgi.ebay.com/ebaymotors/Nismo-Nissan-wheel-Decal-Sticker-_W0QQcmdZViewItemQQhashZitem2eb5f36b6bQQitemZ200621124459QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    • Hi all. So I have my GTR on the lift and have been working on it a few days and today I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
