Hey
I finally seen my NM35 today at my mates compliance shop. Very happy with it. Im going to start servicing it tomorrow and Im trying to sort out what oils it needs.
Ive been searching through all the threads on here to check what weight oils I need but its very unclear and messy in the threads. I think the list below is correct, can someone let me know what weights are? Dont need brands, thanks.
Engine: 5w-40
Oil filter: NIssan
Front diff: 75w-90 GL4?
Rear diff: 80w-90 GL5? for LSD. Also not sure if it has LSD or not, I assume the weight will differ between the two? If so what are the correct weights for either LSD or NON LSD?
Transfer case: Matic J
Trans: Matic J
Attesa: ?
Brakes: DOT 4
Coolant: Nissan
Also I rang Nissan today for a price on the passenger cam cover seal, its ~$30 and 3 weeks from Japan. Anyone know who might have them in stock now?
Thought I would just do the gasket at the same time as the spark plugs to save doing it later down the track if needed.
If there is anything else I have missed please let me know.
Cheers guys
Edited by slippylotion
If it has an LSD it needs an LSD additive in the diff oil. I'm pretty sure if it has HICAS it has an LSD.
I used the same weight in the front and rear diffs, think it was 75w90, and the same oil in the transfer case and trans. I believe you can use the same in the ATTESSA and power steering too (I never changed it).
I went 10w40 for the engine, but close enough. It's all close to personal preference.
Filter is the same as a 350Z... that's been covered many, many times.
Funnily enough, I called Valvoline's info line, and they had NM35 Stageas on file, knew all about them, and knew all about the different oils and fluids.
There is a thread which makes this clear, it's just the brand that varies. Valvoline and I think Nulon make a Matic J equivalent if you can't get the Nissan stuff. I paid about $120ish for a 20L drum.
Thanks Ryan. Does your car have an LSD and HICAS?
So if its a 250t rs four it definitely wont have an LSD?
Cheers
Mine has neither LSD nor HICAS.
I believe an LSD was an option on the RS, mine just doesn't have it.
Haven't bothered to research them yet to work out if I can get one to fit, not high enough up the priority list.
Also found the rear diff on mine had a magnetic sump plug. Think the front did too, but not the actual engine.
As others have said; if you have HICAS, you have LSD. The HICAS rack is very obvious when you stick your head under the back end.
I have a 250t RS Four and it has HICAS & LSD; is good :ph34r:. A quick look should answer your question. If you want to cover your arse; it won't do any harm to use an LSD oil in a normal diff, the LSD oils just don't have friction modifiers in them.
Also regarding the Rocker Cover Gasket; I got one last week and it had to be ordered in; only took a week. Depends when in the cycle you make the order; it could be the day before they ship their 2 weekly lot; could be the day after. I've never waited longer than 2 weeks so far.
Ok. It doesnt have HICAS so Ill asume its not LSD.
So are the oil weights listed above correct?
Seeing as the rear diff is not LSD I will use the same 75w-90 oil weight as the front diff.
Ill also use matic d for the power steering and ATESSA.
Thanks
When I did my research I found that power steering and ATTESSA weren't that fussy. You could use the same fluid as you did in the trans.
Yep :thumbsup: they're just hydraulic pump circuits; any hydraulic fluid would do (any ATF type) there's only pump vanes & seals.
It's only when you introduce friction materials (clutch plates, bands); the type of fluid must match the friction material.
Does the m35 have only proper mechanical LSDs? Some C34s have a viscous lsd which is a sealed unit so that ordinary diff oil can be used in the diff. On the other hand I have an R33 GTR mechanical diff in mine (as does the 260RS and maybe some other) and I use Motul Gear Competition 75W-140 (for lsd) in that.
i would imagine its viscous. a mechanical diff in a family wagon? yeah not a good idea lol
I'm not sure; mine's pretty notchy under power, feels nothing like my old cone LSD that was preloaded to the shithouse; much tighter...
Might just be that they don't cop such a hard time at stock power output; so they're nice & fresh.
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
