So wow, scotty nm35 hit the problem STRAIGHT on. Injector #6 was stuck open and flooded the engine with gasoline, spark plugs went to shit as well and thats why the engine locked. The mechanic managed to turn the car on today so we have that down. Also managed to get a set of OEM injectors for 90 bucks (good deal yay) got some new plugs and problem solved. (hopefully).
BE SURE TO CHANGE THE OIL BEFORE U DRIVE IT!
The engine oil will be extremely diluted with petrol now.
When the injector leakes the fuel makes its way down past the piston rings and into the sump.
white smoke and running rough usually means water in the combustion chamber.
im worried when u fixed ur leaky blow off valve, boost went up, u took it for a spin and possibly blew the headgasket. once u left it parked with the cooling system under pressure coolant has leaked in the cylinder where the headgasket has blown causing the white smoke u mention.
now if it wont start, theres a chance u may have hydraulic locked the engine and bent a conrod or done similar major damage, try turning the engine over by hand with sparkplugs out and then do a compression test.
hope its not bad news for u tho :(
Did u actually read this thread before posting????????
lol I think he didn't...
Spark Plugs changed
Oil Changed
Oil filter Changed
All injectors and fuel rail changed as well
Car feels good, good response. Still feels a bit rich but my mechanic said that's because it threw out a shit load of gasoline through the muffler. >_<
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
