A while ago, I saw an orbital polisher on special for $30 at Autobarn, so I thought meh, might get it and see how good it is.
After being in the box for a few months, I put it to use tonight.
I pulled my front bar off today for a touch up, so I thought I might as well take out my headlights for a clean.
Sanded it with 1200 & 2000 grit then finished off with a hand polish. After hand polishing it, it was still a tad murky. So I gave the polisher a go, and after a few mins.. The headlights look brand spanking new again! :D
But I have a question, what do I do with the buffer pad? Do I just wash it and dry it?
Here's some pics:
(Top headlight is hand polished and bottom is machine polished)
https://www.sau.com.au/forums/topic/370677-30-orbital-polisher/
when i worked in mitsubishi in pait rectification they were just put through a washing machine, at home i just wash in the laundry tub with water.
Cheers, will clean it tonight :)
Also, any tips on polishing my car with that thing? lol
First we used a rotary buff to polish with, then the orbital with an egg crate type pad to get rid of marring (the swirly bit you see after polishing) sort of like what you see here http://www.ebay.com.au/itm/6x6-High-Gross-PolishingPad-Buffer-Pad-Car-Polisher-/180681082040?pt=AU_Power_Tools&hash=item2a116e84b8 but its for velcro backed polishers. Just make sure the polish doesnt get too dry and keep the pad clean.
First we used a rotary buff to polish with, then the orbital with an egg crate type pad to get rid of marring (the swirly bit you see after polishing) sort of like what you see here http://www.ebay.com....=item2a116e84b8 but its for velcro backed polishers. Just make sure the polish doesnt get too dry and keep the pad clean.
I bought black waffle pads from that seller; they're great! Bit slow on delivery tho'
This is what I did with them yesterday:
Reflection? post-61153-0-26778900-1310425114_thumb.jpg Try not to look at the ugly bloke; post-61153-0-56895300-1310425163_thumb.jpg
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
    • Sydney Tools have them for ~$3400. More than the Quick Lifts but these seem better. https://sydneytools.com.au/product/quickjack-7000tl208240v-5175642-7000lb-110220v-portable-light-duty-truck-and-passenger-car-lift-system
