I've recently purchased some Work Emotion CR Kai's in 18 x 9.5 for my series 2 r33. Yay for me.
Now, the offsets are +20 and +38. It was always my understanding that on a staggered set the lower offset was meant for the rear. But when I went to put them on the car, I noticed the +38's didn't clear the stock front brake calipers properly, like they were just scraping the edge of the caliper.
So I put them on the other way around to how I thought they were supposed to be. They fit sweet this way but the front looks a little more pumped than the rear which is a bit weird.
It's +20 on front and +38 rear now, which is odd way around right?
Should I have them around the other way ideally? I'm assuming I'd need spacers to fit the +38's on the front. If this is the case, what type of spacers do I need? Where do I get em etc?
I've heard the type of spacer you need varies from what wheel type you have?
Also, I need new hub rings for the rears, does anyone know what measurements to get for these wheels and where to get em? Repco or something?
Edited by tuna_144
https://www.sau.com.au/forums/topic/370690-offset-and-spacer-help/
The +20 will be for the rear. Just buy a 3mm spacer if it only just touches the caliper, or depending on where on the caliper it touches you can shave/file a little of the caliper, but only if its hitting on a logo or something not important, I wouldnt really do it though.
Just take the wheels of and measure the inner hub diameter of the wheel and the outer of the hub on the car, will be something like 66 and 73 mm.
Spacers are Illegal so if you can sell the fronts and buy ones with better offset.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
