Hi all,
I am currently in the middle of some more work on my GTR and after some recent upgrades I have a bunch of high quality parts for sale that I don't need anymore
Here is the start of it:
1. Complete Set of Genuine R34 GTR RB26DETT Engine Covers
These are impossible to find in good condition! This is the full set consisting of both Cam Covers, Timing Belt Cover with perfect condition CAS Seal, and Valley Cover with perfect condition centre badge. The Cam Cover seals are also in excellent condition so won't need replacing, simply fit them up and totally transform your engine bay! Most BNR34 covers (If you can actually find them!) are in terrible overall condition, and the rear section of the valley cover underneath the mount for the ignition module is usually snapped off - These however are in great condition.
post-46-0-64968800-1310437160_thumb.jpg post-46-0-60497100-1310437174_thumb.jpg
I am asking $550.00 Firm
2. HPI Japan Stainless Turbine Outlet Set - BNR32/BCNR33/BNR34
HPI Dump Pipes are extremely well made and manufactured in Japan, and feature a massive free flowing bellmouth design. HPI Dumps are the largest off the shelf Dump Pipes currently available for GTR's at ~76mm (Tomei Expreme Dump Pipes are only 68mm!.) Immaculately welded with nice chunky stainless flanges!
These have had minimal use and are in very good condition
post-46-0-18258100-1310437183_thumb.jpg post-46-0-52544800-1310437195_thumb.jpg
I am asking $495.00 Firm + Postage - ($929.00 Brand new from Just Jap!)
3. Jap Carbon Fibre Rear Wing Blade for R33 GTR
Lightweight Carbon Fibre Rear Wing Blade for R33 GTR - Purchased from Japan some time ago
I am asking $299.00 Firm (Pickup Preferred)
4. Used Genuine Nismo Oil Filler Cap
No explaination needed - Genuine Nismo Oil Filler Cap in good condition (Part Number: 15255-RN012)
I am asking $50.00 Firm + Postage
All parts available for pickup in North Sydney.
Happy to post Australia-wide at the buyers expense, with the exception of the Carbon Wing blade (I'd prefer local pickup on this)
Cheers! :)
https://www.sau.com.au/forums/topic/370701-gtr-parts-for-sale/
Hi im interested in the hpi dumps isis there any clearance issues when using these hpi dumps I have heard apparently that the mines dumps being 70mm are extremely close to the inlet on the secondary turbos. Cheers Garth
Hi mate,
No clearance issues, they are a direct fit and very well made.
Cheers :)
do these dont have provision for exhaust temp sensor for 34r vspec?
They have a provision for the 02 sensor yes, from memory on a a BNR34 V Spec you may need the adapter if you have a small size 02 sensor but they are cheap and easy to get from Just Jap
Cheers.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
