Didn't read anything but posting anyway. 1 point can be lost for almost any reason. If you buy an R34 GTR, chances are you may get pulled over and probably defected. 1 point gone.
they dont give points in melbourne for getting defected buddy
  • Replies 89
Posted Images
I've only ever driven fairly quick ones, so my viewpoint is no doubt skewed.
wish the skylines had a closer ration box tbh.
how is it skewed? the speed you will get out of a gear is determined by the gear ratio and rev limit. power has nothing to do with it. you could have a skyline putting out 800hp but if it's running the stock gear ratios and stock rev limit it will do no faster in each gear than a stock skyline. the only exception to this is 5th gear where the stock skyline will probably run out of puff before it hits redline while the modified one would be able to hit redline, but the theorhetical top speed is the same.
Yeah I understand how gearboxes work, thanks Lol.
the few I am talking about can and do go above the stock rev limit, in 5th gear, which a stocker more then likely wouldn't do, plus I was more really getting to the acceleration point then anything else.
Anywho, this is circumstantial to the topic at hand man, ASS AND TITTIES, ASS AND TITTIES YEEEEEEEEEEEEEW.
So how come you dont get full points after you have already lost your license? I thought that the 1 point or 3 month option was only if you were about to loose your license, thats what happened to me a few years ago and I just took the 3 month option, 3 months isnt much really to wait, just think of it as a time to save money for your gtr.
in QLD they stick you back on your Ps for a year after you get it back. so 4 pts no alcohol as a starter. trust me I know it well.. if you are a kid then you will lose it again. me I was a bit of a twit for the second one as I forgot to renew mine.
take the suspension learn from it , get so exercise and get in shape. you may look at it as 3 months without a car - I looked at mine as a walk to work every morning and a way to shed a bit of weight :)
NOW if you have not learned your lesson after that then they get a bit more unfriendly and threaten to lock you up.
moral - there is a time and place for being a twit - pick them accordingly and FYI industrial estates are not one of them.
I have been told twice to be a good boy - one for 6 months the other for 1 month. I stick within the limits now and I have little issue.
Im too lazy to scroll up and see who wrote this
I mean really, if your speeding anything over sort of 10 up in a built up area where you cannot possibly predict what is coming from where, you deserve to get hung anyway.
I couldnt agree more. Im still 'enthusiastic' but no way would i do more than 10 or so over in a built up area, Free ways with someone ahead of me bombing along at triple figures then..well, how many here could help themselves? Had about a dozen cases where they got the disco lights while i had time to slow up and trundle by eyes like saucers..good times.
couldnt agree more with above post too, 1 point is just too stressful to drive on. Im shocked i lasted 11 months before getting cocky. still self face palm whenever i think about it.
do the 3 months.
twice i picked the 12 months (one by choice, the other due to stupid vicroads), and ended up with pretty much 2 back to back 6 months. was about 4 months in the prelude till bloody police set me up with a driving without seatbelt.. :(
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
