Hey guys,
I used to have a gym membership, but I always found it too much effort to actually 'go' to the gym, so my money was getting wasted.
For about the past 6 months I've been working out at home, for me it works much better, the only problem is its difficult to exercise some muscles properly
We have here:
-Dumbells
-A barbell
-Bench press (also does incline etc)
I'm also hopefully buying some sort of setup that will allow me to do lat pulldowns soon
Anyways, these days my workout consists of:
-5km run
-3 sets of 10 diamond pushups
-3 sets of 10 incline bench press
-3 sets of 10 bicep curls
-3 sets of 10, erm, dunno what you call them but you hold your arms bent in front of you and raise them at a 45 degree angle upwards and outwards, works your shoulders + delts
-3 sets of 10 dumbell bent-over row
I do that 3x a week, plus I do an abdominal workout 2-3 times a week on my rest days.
I am a skinny bastard (63kg hah), but after about 4 months of hitting it hard its fiiinally starting to show some results :)
Anyone else got some good excercises for around the house?
https://www.sau.com.au/forums/topic/370749-working-out-at-home/
  • Replies 41
These are exercises that I like to do with dumbbells (I workout at home as well)
DB Flyes
DB Press
DB Bicep Curl
DB Zottman Curl
DB Shoulder Press
DB Arnold Press
DB Squat
DB Upright Rows
DB Rear Lunge
DB Shrug
Goto bodybuilding.com if you want to know what that are etc.
-5km run
someone already suggested it but just get one of those towers so you can do pull ups and dips
you don't have any exercises for your side delts so throw some laterals in there... standing
throw some overhead presses in there (dumbells or barbell) and some upright rows (for your traps)... maybe work up to some power-cleans, but be careful with form
but most importantly you need to strengthen the posterior chain (your back/spine)... so deadlifts and good mornings... this will help all your other lifts
no leg work?
I can't wait til I get my home gym up and running... I find I get a better workout at home but I'm not setup properly yet so its off to the gym for me:(
At home to keep up interest, try to always run two things simultaneously.
1) Physical routine &
2) Mental stimulus, fun & preoccupation
Without the latter, it's hard slog.
Motivation is a killer.
comes to 7:30pm at night and you can train or watch tv. damn that tv
For lats just buy a power tower i think they are called. Can do chin ups and dips on them. Best investment ever, do eet
edit: something along these lines here
Jebus, $400?? Anyone know of any cheaper ones? Heh.
no leg work?
Cheers man, some good advice in there. Yeah no leg work yet because after running 5km they are shattered. I might try some squats now though. As it is after this workout I end up shaking, can barely lift my arms to raise a glass haha.
Yea, sorry mate, that was just an example. I used to train at home and the one I have here cost me like $250 IIRC. I wouldn't recommend getting to cheap a tower because the really cheap ones usually flex around a little when you're doing dips on them. Not very inspiring...
Those tower 200 door gyms look like a good thing. Does anyone on here use one?
I'd love a gym at home again. Had to sell my setup when I moved house. Really can't be f**ked going to a gym to work out. I did for a while, nut found better gains and more motivation when working out at home.
I think I may buy me a tower 200!
So here's a question.. How the hell do you guys do squats at home? I managed to lift a 30kg barbell over my head, but I found actually doing the squats fairly easy. Upping the weight just made it impossible to lift over my head. Any ideas?
Clean and jerk the bar for front squats? I used to do dumbell squats...they were good for the traps too :)
yeah you really need some sort of rack... you can do the front squats or dumbell squats as has been suggested but if you want to go heavy you might have to go to the gym
there is a trick to using lighter weights at home but making the exercises harder... try to be really strict with your form and take 1-2 seconds in the positive movement and 4-6 seconds in the negative part... so for squats, squat down really slowly (it will feel strange going so slowly at first) and as deep as you can without losing your balance or lifting your heels or toes off the floor, then explode up... you can even turn it into a jumping squat when your comfortable with the weight
also try split squats with dumbells and even one legged squats... do a search on youtube for squat variations and take your pick
we did these last night and they suck... but you won't need a lot of weight at first so could be good for you... ignore the rack in the vid you could do these with your 30kg barbell and really feel it! I'm in pain today
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
