Attessa Fault Code 21 - Tps
Thanks for the explanation, sophisticated WMI setups aren't too common here in the land drop bears so. Only reason I'm curious is because I feel that the end of bowser E85 is coming. Just a matter of time. -
oil pressure sensor sits on the filter block, i believe after the filter but i may be wrong about that.
Yes and no. My second sentence is trolling but being that you're also from North America, I was really hoping you would catch onto my ICP reference. Then again, I'm probably one of the only idiots who listened to ICP when I was younger. Jokes aside, if the magnet went in through the drain hole, then I'm sure you can get it out by there. Try some of the options the others have listed.
