R34 Stereo Head Unit Wiring Diagram For Pioneer Deck & Handbrake Bypassing
Hey guys,
Just thought I'd make a DIY post for people wanting the correct wiring diagram for connecting a Pioneer head unit ...
Im making this post because I struggled with the general diagram and the colours were not matching correct so if you got Pioneer, your in luck.
Pictures are attached but I wrote it down also:
NOTE: May work for other models but this is specifically for R34 Skyline with a Pioneer Head Unit.
Car: Dark green - Stereo: Yellow
Car: Orange with black strip - Stereo: Red
Car: Red with blue strip (in image below its yellow.. used to extend it) - Stereo: Orange with white strip
Car: Grey with blue strip - Stereo: Blue with white strip
Car: Orange - Stereo: Purple
Car: Black with pink strip - Stereo: Purple with black strip
Car: Pale green - Stereo: Green
Car: Black with yellow strip - Stereo: Green with black strip
Car: Brown - Stereo: Grey
Car: Brown with white strip - Stereo: Grey with black strip
Car: Blue with white strip - Stereo: White
Car: Blue with yellow strip - Stereo: White with black strip
Hope this helps if you needed it..
Also if you need help with bypassing the handbrake I worked it out too, if its an old model DVD head unit you can just tap the wire labeled handbrake into the ground wire and this will allow you to have the DVD open while driving.
Although if you have bought a new model pioneer head unit, you cant just ground it, it wont work so what you have to do is on the wiring harness that comes with the pioneer head unit, there will be a wire labelled "mute" (this wire is not needed) so remove it without damaging it and you will need to move it to another port on the plug. You will see on the plug where the wires come out that there are two black wires coming out, but there is a empty gap between them.. now insert the mute wire into this port (make sure it clicks in). Now strip the end of the mute wire and tap it into the handbrake wire. Now that the mute and handbrake wire are connected together you can now ground it or tap it into the ground wire. This will then allow you to have the DVD screen on while driving and if it has a GPS you can now input the address without stopping the car and pulling up the handbrake first.
I know the handbrake bypassing sounds complicated if you have the new type but ill be glad to help if you want to ask any questions or need more detail on certain steps.
Very helpful Benny boy.
This should be stickied. This is the only thread you will find showing what the factory R34 stereo wires connect to.
Edited by PAV34
  • 2 months later...
Hey, I Got new Pioneer AVH-P2300 DVD unit and wanna know how to Bypass hand Brake on this Unit.
1) do i need to Buy any add on Device to work ?
2) Any simple trick & tweak?
Thanks in Advance
the way i bypassed my clarion dvd player is a switch yeah shonkey but not as bad as not having dvd screen at all, just a wire from the ground to the switch and the handbrake wire off the deck to the switch, in the ashtray and tadaaa you want dvd just flick the switch.
  • 2 years later...
IMO this should really be (for ease for everyone who is doing this):
Car: Dark green - unswitched power (battery)
Car: Orange with black strip - switched power (ignition)
Car: Red with blue strip (in image below its yellow.. used to extend it) - illumination (so when your dash lights come on, the screen dims so it doesn't glare at night)
Car: Grey with blue strip - remote (or antenna?)
Car: Orange - rear right speaker +
Car: Black with pink strip - rear right speaker -
Car: Pale green - rear left speaker +
Car: Black with yellow strip - rear left speaker -
Car: Brown - right front speaker +
Car: Brown with white strip - right front speaker -
Car: Blue with white strip - left front speaker +
Car: Blue with yellow strip - left front speaker -
For the earth you can just put a ring terminal under the bolt on the panel holding the gear shift boot. Easy to access.
Edited by sleptema
  • 3 weeks later...
Perfect thanks lots!!!
  • Like 1
  • 9 months later...
Just for anyone who might be wondering, in GT-X models that included the Xanavi GPS/TV Package & Skyline Holographic Sound option from factory, the antenna booster wire is actually red with a white strip. There is still a grey wire with blue strip in the loom, but at this stage I haven't been able to work out what it actually does.
  • 3 months later...
just found out today while hooking up a new head unti into my sedan with holographivc sound - the grey with blue is the amp for the rear speakers. crappy flat sound from the back if the hu remote turn on wire (blue with white stripe) isnt hooked up to that wire, full sound when connected. its the standard nissan amp power on wire
  • Like 1
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
