Orange s15
As Above selling my pride and joy it has
Always Gets oils and filter every 5K and full service every 10K
70,000kms
Drift R 18" wheels
Trust Front mount intercooler
Spitfire Coil Packs
K&N pod filter
3" Dump pipe
3" Front pipe
Hi Flow Cat
3' stainless steel Cat back perfomance exhaust with twin 3.5" tips
Full body Kit
Orange pearl Paint
Custom orange Interior
Front 6.5" Splits
Rear 6.5" Coax
10 stacker cd player
Nismo coils and shocks front
HKS coilovers rear
Nismo Shift knob
Nismo Front and rear strut brace
r33 rear brakes
Comes with both stock and tinted tail lights
In vic
Rego till 09 nov
selling due to buying a 4x4 needed for work :(
am open to offers for quick sale or swap for R33 GTST with at least 8K my way and happy to remove parts to make it cheaper
0433663833 Thanks
Edited by VicSlidin
https://www.sau.com.au/forums/topic/370822-s15-1999-jdm-spec-r/
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
