Iv got a hks ssq bov that doesn't flutter was wondering if there's any way to make it? Don't get me wrong I love the sound of the standard sound but would like to hear Wat it sounds like.fluttering any ideas?
There is a bolt on the back for adjustment..
Thanks
-Jayden-
https://www.sau.com.au/forums/topic/370845-hks-ssq-bov-flutter/
Thanks
-Jayden-
Want flutter? Don't run a bov. A bov is designed to stop compressor surge (flutter)
How do I achieve flutter with out surging?
Blank your bov or block the vacuum line(not with stock bov because it will still open on full boost). im not sure on the hp limit but i wouldnt do it over 300hp. someone should be able to shed some better light on the subject.
Edited by Blueone
^ Shit post is shit
Tightening the BOV or blocking it is just going to cause compressor surge. Stao told me to avoid any compressor surge but I really do like the sound of it.
Only if you tighten it too much.. I think you will find that true compressor surge is actually when the engine cant swallow the boost the turbo is throwing at it.
It will frighten you...
^ Shit post is shit
Cool story bro!
having no BOV does not cause compressor surge :thumbsup:
Agreed. It was a simple question with a simple answer. if you dont like flutter, then f**k off and dont post. Noone cares what you have to say.
So anyway, back OT, im guessing there will be a little locking nut you need to undo, then wind the screw in a few turns, and re lock the nut.
Just try it on different settings untill you find a sound you like.
I have a Greddy Type RS and did the same. I didnt want flutter, but having it really loose sounded poop, so i tightened it up a touch. I get flutter at very low load/boost and light VAC, but once the boost is up a few psi it opens properly.
I dont see it causing any harm. Has been like it for a year or so now.
Thanks mate did just that it sounds great but I'm running standard turbo standard boost and it sounds like its coming out of the pod but coz its low boost it can't do n e damage can it ?
I ran my stock turbo with a blocked BOV since I bought the car. Took it out, there is very minimal shaft play. Never had any issues. The sound will be coming out of your pod.
Some people think flutter is the bov opening and closing rapidly... I don't think this happens. Although those are generally youtube comments. I'm gonna reinstall my turbosmart BOV after I get my plumb back adapter and tighten it up so I get flutter on low boost but don't risk damage on higher boost.
lol to all the people saying surge isnt flutter, they are teh saem thing as the car above on the dyno, just happen when you lift off instead of under load. As far as the turbo is concerned it is the same thing(running too far to the left of the compressor map past the surge line)
Reverb.
The trapped boost pressure when the throttle plate is closed has no here to go but back out through the compressor turbine and out the airfilter.
A BOV releases this pressure so it doesnt have to force its way back through the turbine.
I run my BOV's fairly tight so at low boost you get a reverb(flutter) but anything over 9psi the bov helps to release the pressure.
I have never seen or heard of a turbo dieing due to this.
Compressor surge is not flutter.
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
