You will be hard pressed to find any on this forum with those turbos in a twin setup.
You would also assume anyone with those turbos would be thinking about power more than they are lag. Most people on this forum would consider ONE of them laggy making a little over 300rwkw. Two would be shy of double and obviously very laggy.
GL
https://www.sau.com.au/forums/topic/370855-hks-3040/#findComment-5912378
Yeah single form you are in the 300-330rwkw region on PULP.
So two of them, 650rwkwwould be a rough place to start the guess work.
If a 3076, smaller than a 3040... comes on round 3000-3300rpm in .86 form on a high comp 3lt, you'd expect about 6000rpm in twin, which won't have high comp given the boost that'll need to be used.
Depends on rear housinsg being used of course.
Hope there if a rev limit of 10,000 at a minimum :D
You chasing 600rwkw+ or not?
https://www.sau.com.au/forums/topic/370855-hks-3040/#findComment-5912565
Some people consider that 2530s and GTRSs and GT2835s and GT3037s can be a bit lazy in twin form on an RB26 .
I think GTRSs is as far as I'd go on anything with number plates even on a 2630 .
IMO from the GT3037/GT3076R and up is getting a bit extreme on anything other than a single purpose drag car . Like most I've read articles on the Japanese with their denuded slingshot cars but they are not something most would want to use for anything else , basically bloody useless except for the very rich on a drag strip .
It takes a lot more that two bigish turbos to make a GTR a drag king .
I couldn't imagine an engine that was a clapped out Camry one to 6500 revs then an unguided missile thereafter .
Anyway on paper the HKS spec GT"3040"R , todays speak called a GT3082R , is a better one than the one Garrett generally markets though they've been around long enough its exclusivity rights to be over .
I'll look up the numbers later so you know how to ID each type .
The only real difference aside from a HKS turbine housing is the compressors trim which is 50 on the HKS variant and 56 on the one Garrett usually sells . Same comp housing same center section .
A .
https://www.sau.com.au/forums/topic/370855-hks-3040/#findComment-5912825
The cartridge numbers for the GT3040/GT3082R are 700177-9 for the 50 compressor trim HKS spec version and 700177-14 for the 56 compressor trim version Garrett usually push .
Sadly the 56T one was very common and there are a fair number of them in circulation .
My HKS list quotes the GT3037S 56T (port shrouded comp cover version same as GT3076R Pn 700382-12) as being 480 PS and their spec version of the GT3040/GT3082R (50 comp trim one) as 500 PS .
The reality of the matter is that half an RB26s 2568ccs or 1284cc isn't a lot to have to spin up a 500 odd horsepower turbocharger . Try to imagine a GT3040 on a Suzy GTi 1300 .
A .
https://www.sau.com.au/forums/topic/370855-hks-3040/#findComment-5914621
Correction **bottom of the mop bucket.
ive heard Hayabusa turbo's are pretty safe. i mean they only lift the front wheel from the power until about 280km/h n then its pretty stable...:worship:
http://www.youtube.c...FC7ADCDEBC9CF8E
Edited by jjman
https://www.sau.com.au/forums/topic/370855-hks-3040/#findComment-5915090
Exactly the reason that twins on a 26 will be sweet, just raise the rev limit another 7000rpm and wheel stand goodness at 280km/h.
https://www.sau.com.au/forums/topic/370855-hks-3040/#findComment-5915095
Actually Busa engines are not in short supply 2nd hand . You go down to your local wrecker and say I'll have that one , they wipe the blood and hair off and box it up for you .
The point I make is that 1000 horsepowers worth of turbochargers is pretty extreme for a 2568cc car engine if its used on the street .
A .
https://www.sau.com.au/forums/topic/370855-hks-3040/#findComment-5915869
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
