Well finally, Shell V-Power has landed in WA to compete with the likes of BP Ultimate 98 and Caltex Vortex 98.
Anyone tried it yet, apparently it has been available at some sites across Perth already for the last few days.
I know I tried it in the R34 GTR when I was living in Melbourne and did notice some difference.
https://www.sau.com.au/forums/topic/370861-shell-v-power/
  • Replies 50
My local shell just under went a few weeks of maintenance so I wonder if they stock it now, crn warwaick and glengarry, but not driving skyline ATM so haven't bothered to check it out, may swing by this arvo for a gander
https://www.sau.com.au/forums/topic/370861-shell-v-power/#findComment-5913231
as stated in the other shell v thread in events section
Coles Express BICTON 394 CANNING HWY (CNR WADDELL RD)
Coles Express CLAREMONT 269 STIRLING HWY & MARY ST
Coles Express FREMANTLE 101 HAMPTON RD
Coles Express BENTLEY 1128-1132 ALBANY HWY
these are the shops that have it now
https://www.sau.com.au/forums/topic/370861-shell-v-power/#findComment-5914094
Benefits of v-power over bp ultimate?
Went to the little shindig they had on riverside drive last friday but yeah, only went for the remote control car racing.
They talked about it being better because it keeps valves clean... isn't that what ultimate is supposed to do anyway?
https://www.sau.com.au/forums/topic/370861-shell-v-power/#findComment-5914401
We even have stupid laws that prevent the widespread distribution of E85 etc :(
On the plus side (or negative side depending on how you look at it), we have one of the most loose P-plater laws with no car restrictions at all. I was driving my R33 GTS-T 2 weeks after I got my Ps... :whistling:
Cheaper, especially if you use those 4c Coles shopping dockets...
https://www.sau.com.au/forums/topic/370861-shell-v-power/#findComment-5914550
If there are any SAU WA Members that attended V-Zone on Friday, & would like 20-30 words to be included in a review I'm doing of it...
PM me and i'll include/quote you :)
I also have the full listing of the 40 locations you can get it from.
Will also post all that info up for you all as part of the review :thumbsup:
https://www.sau.com.au/forums/topic/370861-shell-v-power/#findComment-5914558
jza70 with big single and external gate a few months after i got my Ps...then a jzs147 aristo (2jzgte)
https://www.sau.com.au/forums/topic/370861-shell-v-power/#findComment-5916204
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
