I know people love the idea of wider is better, but there is a point on a track where the tyre simply gets too wide to work properly. So with an an R32, in a very moderate state of tune (300awkw will be all I chase) and not a track weapon, Just a weekend warrior here and there, would 9.5 inch be getting too wide? Then what size tyre (17" wheels)
Basically an R32 is overweight and pretty hard on its tyres - particularly the front. So you could live with alot more tyre than you can fit on the (standard) things.
Also you have to filter out all the fitment spam. R compounds dont need or want stretch. Also they tend to be a little larger than a nominally same sized road tyre.
If it is a track tyre then you have to decide what kind: eg a proper slick or a semi slick or something else.
An R32 will run a 255/40 r comp on a 9" +22 rim with a little scraping on the rear. Roll the lip of the rear guard like everyone does & you will be ok. You must adjust the suspension to make the tyres work & not to make them fit.
But understand (as an example) that a 235/45/17 is cheaper than a 255/40/17 which in turn is cheaper than an 18" tyre. Also that not all sizes are available in all brands. Bridgestone dont make a 255 width in an 18" RE55 for example which is probably what you would run if you could.
Anyway to answer the short question in short:
Use 17x9+22 & a 255/40/17 rim. An r comp with your ride hight will foul on the lip of the rear guard so get them rolled.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
