Well the story goes like this. My old ceffy had a bit off a fight with a rockwall so i bought another ceffy rolling shell which this time has a sunroof but i can't get it to work. The other drama is that the roof lining sits a little lower so i cant fit my 6 point roll cage in it.
I figured that i dont really care if i have a sunroof or not, i personally dont see the point. So i think i might try removing the whole sunroof mechanism, sealing the glass sunroof shut, corering it with a carbon fibre sticker, and swapping my roof linings over from the old shell. Just as an easier cheaper option
Fingers crossed all goes to plan.
Good God don't do that.
Generally, non-sunroof cages CAN fit but they're a very very tight fit.
If it's track only, take the roof lining out, and that gives you a bit more room, that's about 1/3 of the height difference, the other 2/3 being the sunroof assembly itself.
Sunroof is all sorts of fun, and it makes you an instant sickcvnt...keep it :P
I dont know how someone has fitted a non sunroof cage into a sunroof car, the height difference is signifcant. Keep your cage, remove your sunroof and replace it with a sheet of perspex. I used tinted perspex so its not so bright on a sunny day. It obviously wont open but good luck finding a sunroof model cage.
I was going to say before, look at getting it chopped down.Surely the cost of cutting the flanges and bringing the whole cage down 1-2 inches isn't THAT much ?
Sure as hell beats ripping out a perfectly good sunroof and making a dodgey roof. That right there is $500-$1000 value on your Ceffy come the day you want to sell it.
Hmm i think your right
    • And at over $2 per litre I'm starting to consider setting up a corn mash still and converting over to alcohol and running mine on it !  Up side of that is it all doesn't have to go into the car ! Win win !
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
