Hey guys,
Just been reading up through the epa guide lines and it states that no modified or aftermarket plenums are permited... So this means anyone with the greddy style plenum will have issues?
Just wanted to confirm with everyone. Anyone been done for it?
Cheers in advance guys. :-)
https://www.sau.com.au/forums/topic/370950-aftermarket-plenum-not-epa-friendly/
i think the answer to your question is yes and yes.
although i thought it came under the 1 intake modification rule, but based on what your saying thats not the case. if it says illegal then its illegal.
If that's what is in the guidelines, then you've answered your own question.
As to whether anyone has been picked up, that simply comes down to luck.
Some people probably have, some probably haven't... That's not to say it wont happen tomorrow.
and it would depend how it looks too
if its all grey dark and oem looking and looks standard you might be ok
if its got HKS and greddy plastered all over it with shiny parts and nice blue coloured joiners etc
then its likely to get more noticed
Get it engineered then its all legal. For the intake plenum you'd just have to make sure the tune is correct, as GTRR34 says because the AF is different.
Do all your intake mods at once before doing the engineers though, as it will be expensive.
not to mention that with all aftermarket ecu's being illegal, you therefore can't "make sure the tune is correct"
(even if the tune is better for the environment than stock) go nanny state!
my case.
f**kn stupid i reckon.
but im told that a stand alone ECU which is locked after a tune can be engineered.
its only PBacks that cant be eng'd.
or was I being trolled
I had a Greddy copy on my 180, the boys at EPA still passed the car, guess they like me
Aftermarket ECU's can be legal providing they pass a special emissions test (which i was told by Lou at EPA is about 3g and if you fail there goes your 3g) and it must be locked.
Well technically you can pass with remap since you cannot tell from visually checking but the problem is passing the a/f tesf they do, so even if you did get an ecu engineereed but it failed the emissions test it still doesn' t help.
And how do you lock it? a factory ecu is considered locked but is it really locked?
Unless im mistaken you first need to pass the emissions test before you can get it engineered.........
my case.
Once you pass the ADR emissions testing aka: "3k if you fail, tough. You have to pay it again".
Victoria, fail state.
you know what is really stupid..
Adding an aftermarket plenum and nothing else would have zero affect on emmissions and would actually make the car slower yet some how its deemed bad enough to consider it defectable..
f**kin victoria
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
    • Good question, I don't really know tbh...I'm pretty stock thought, where could I check this?
    • This. I'm confused by the whole discussion. The only reason you would have a car with e85 only if it was track use and you only ever used e85. All other use cases you add a flex fuel sensor, do the flex tune (you only need to do a couple of % and then interpolate the rest) and then you put whatever the hell you feel like including a mix in the tank and it just works. Want a long drive? fill with 98 Want max zoom? fill with e85 Got a half tank of 98 then find e85 somewhere? Throw it in.
