  • Replies 54
Yep still fine man :)
My girlfriend has been taking them aswell and no negative effects.
One day I had a tiny bit of a fishy taste from a burp a couple of hours later but that's only because I was running late for work, didn't eat breakfast and only had the tablet.
  • 5 weeks later...
i use Triple Strength Fish Oil from GNC
http://www.gnclivewell.com.au/product.asp?id=88&t=Triple+Strength+Fish+Oil+GNC+&cid=8
1 a day, dont see many noticeable results, but I didnt when I was taking 6 a day of another brand either.
It might work better if taken in conjunction with Musashi Inositol
Inositol and EPA/DHA collectively strengthen the myelin sheaths of cells.
And Plan C is to also introduce Coenzyme Q10 whilst working out.
I can't say that the above is the answer for you; but at least it's a process of elimination.
  • 3 weeks later...
My order turned up late last week of the same brand Phil got, i did the premium though.
So far only taking 1 per day and I'm not getting any major issues with reflux and I get it bad with other tablets.
Very impressed and I'm feeling quite good at the moment. Will report back in a couple of weeks.
I cannot recall any info that says that fatty acid chains are altered deleteriously during the canning process.
Experiment:- try omega 3 at optimal doses for say 3 months then stop > then check a couple of weeks later if your functioning falls off somewhat?
My question was more related to the content of Omega 3, i.e. Is the tuna can a suitable daily dosage?
Experiment sounds good but OCD won't let me do that lol, it'll pickup on some psychosomatic placebo response even if I'm in the control group :P
On the plus side Tiger Balm works wonders for me...
What benefits should I be looking for (bad experimental bias here) when introducing Omega 3 to the diet?
Curiously, if I'm eating a 95gm can of tuna each day, will this give me enough Omega 3 or should I be supplementing with tablets?
My 195gram can of tuna in olive oil contains:
32mg EPA
155MG DHA
Olive oil contains omega 3's, and its ~81% tuna, 19% olive oil.
An omega 3 capsule contains a lot more than that, tuna is not a fatty fish, salmon is :)
Ideally you should be balancing your omega 6 to omega 3 ratio, although I've never known how much omega 6 I'm getting through my diet so I've been taking a small amount of fish oil.
EDIT: Possibly irrelevant but one of the benefits of omega 3 is lower inflammation levels. However, I've found circumin much more effective than anything else for that, its got my tendonitis under control :)
Must report in... Getting slight reflux issues with the Xtend life product, in certain situations.
The only time I do is if I take one soon as I get outta bed. So not having eaten for 8-9hrs.
Long as I have even a small amount of food, its totally fine.
So quite impressive overall
Good to gear man. I've noticed similar. If I take one before breakfast I get a couple of burps after an hour or so.
After breakfast or with any food it's all good.
I'm onto my second bottle now. Got the second one a lot cheaper due to their loyality program thing :)
I get mine in less than 15mins after taking it :D
But ye, overall quite good. Not sure if it's just the oil or the fact im coming off a pretty hefty illness but im certainly feeling quite good the past week since I've started taking it
So what's the deal with fish oil tablets? Been thinking of buying some... I eat about 180g canned tuna a week - would that be sufficient enough to not have to supplement with fish oil tablets?
What brand should I get if I do need some? They will need to be small tablets, I currently don't swallow tablets because my mind say's no haha.
Edited by Dani Boi
