Ok so after careful review, you aren't actually wrong about the last part, you are wrong about the first part.
The only reason you 'USE' more fuel at peak power is because the injector is doing it more times. Peak torque has a higher ratio of fuel usage per rpm compared to peak power. Which is why most fueling and ignition problems occur at around that time but become better as rpm increases.
So, yes, more fuel will physically leave your tank at peak power but you certainly have a higher demand for fuel at peak torque
What you just said is exactly what I said, including you using the ratio of fuel usage to rpm instead of what I said (which was just to say per cycle). So either we are both wrong about the first part I wrote or neither of us are, and I really prefer the latter.
Most ignition problems turn up at peak torque because BMEP is highest at that point, making the mixture harder to spark off.
A lot of fuelling problems turn up at peak torque because that's when it's likely to ping the worst (and hence where pinging will likely start to show), given that BMEP is highest then.
I will quote that part you are wrong about:
"Now that's just untrue"
ok just an update didnt get a chance to do a fuel presure test as when i got hoe dad had taken the car but when he got back told me to take it for a run and the car is runing a lot better still has a little pop above 4500 rpm but its runing a lot better and is holding 7psi of boost now so might pull plugs out and check them and clean them and see if the gets rid of the little pop thanks for the help guys will let ya know how it goes
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
