My GReddy Profec B Spec II Boost Controller is flashing a red light?? when i hit high boost. i run 16psi and some times 22psi it only happen when i run the 22psi it never used to but it happen tonight coming home from work.it has been tuned by crd just in case you were going to say get it tuned or who tuned it. anyway my question is why does it go red.
thank you in advances.
https://www.sau.com.au/forums/topic/370987-boost-controll/
Ive only had mine go red a few times. I guess its a fuel cut or boost cut. Would be fine I just turned my boost percentage down a couple of percen. So that max boost is a little lower but its like normal for the icy mornings.
https://www.sau.com.au/forums/topic/370987-boost-controll/#findComment-5921826
