Hi All,
Just bought a car and very regrettably need to sell my go kart as I now don't have room for it in the garage.
I have had this kart for roughly 9 months. I bought it off a friend and only used it a handful of times. I didn't race, just had some fun on Sundays. I mostly use it at the South Morang track and the handling is awesome and the 125 is super quick, especially when the power valve kicks in.
It is a very good looking kart and I get a lot of comments about it at the track, particularly about the fact that it has front disc brakes.
This is one of the cleanest AX9's you will find, both I and the previous owner were very meticulous with maintenance and cleaning of engine and chassis after each and every session on the track.
The Rotax has only done about 3hrs since rebuild by CC Racing.
Details are as follows:
-Arrow AX9 B-Max 32/32 Chassis
-Blueprinted Rotax FR125 (125cc) - power valve model
-Currently using MG 'reds' tyres
-Full genuine Arrow X1 black plastics and sticker kit
-Genuine Arrow FRONT BRAKES - very rare on this chassis - comes with adjustable bias
-DTM limited edition wheels
-Recently installed new battery
-Large Kartech seat
-Kartech go kart cover
-Genuine Arrow X1 pedals and rear hubs
-Spare Rotax Muffler + other parts including sprockets etc
-Standard 4x4 trailer
Price is $6,000 for the complete package, or;
-minus $700 without brakes (I will put back normal hubs)
-minus $300 without trailer
-minus $2000 without engine and 2no mufflers
I will get some more photos up soon!
Kart is located in Bundoora, Melbourne.
Call me on 0430 337 774 if you have any questions.
  • 1 month later...
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
