Haven't heard anything more. Thinking i'm not gonna get it back.
Starting to get over it..... it's probably so f**ked now anyway.
All i hope is that the wankers get caught eventually and get there arses kicked.
Keep an eye out for parts too... especially my wheels, only recently resprayed in metalic silver, no stickers, 17x8 front, 17x9 rear, had toyo trampio tyres on them.
Surely there wouldn't be too many of these rims freshly painted out there.
Cheers
