Just got back from the preview of the new Aston Martin DB9 at [spelling] belia Volvo in Hawthorn tonight, and what a car...unfortunatley anything parked in the same vicinity as an AM Vanqish suddenly doesn't look so glamourous. But at $750K I guess you'd want it to.
Brought the camera, but decided against taking pics, coz most people had there noses so far up they were blocking the light. Must say though did meet some really amuzing older blokes one in particular a "CEO of a major Transport Co" who was such a laugh, in his late 50's more a rev head than half of us here.
All in all, if anyone's got a spare $400K lying around, and demand hand build craftsmanship with the typical thunder tone of an AM V12, check out the new DB9.
https://www.sau.com.au/forums/topic/37106-new-am-db9/
me n my mates were thinking of pitching in and we came up with about 6 grand that we had spare between us. We plan to buy the tyre or badge or sunvisor of the Phantom at this stage. We'll aquire the car piece by piece, at one piece per year. At that rate, we should own it in 168 years. I hope they find a cure for death, coz I'm gonna be going to my Grave unhappy if I'm about 50 parts away from owning a phantom.
https://www.sau.com.au/forums/topic/37106-new-am-db9/#findComment-743213
  funkymonkey said:
meh, 400k will see me comfortably in a masserati 3200GT convertible with 250k to use towards my condo...
Aaaaah Yeees, I'd be happy one of those also... But it's old technology compared to the 4200
Seriously, I have to say for $ for $ value, not much comes close to a gtr.
https://www.sau.com.au/forums/topic/37106-new-am-db9/#findComment-743891
i've driven down the street in an R34 (elizabeth st) and I've driven down the same street around the same time on a different day in a Bentleigh... lol trust me, the bentleigh turned more heads.
As far as bang for buck the GTR is great, but when you have oodles of moola oozing out of your orifices, that means shit... bring on the Bugatti Veyron 8.0L W16. Two narrow V8's welded together to form a W shaped Engine with Quad turbo's takes the car from 0-100 in under 3s and 0-300 in under 14s. The speedo goes up to 450km/h and the top speed is 406km/h. Oh and get this theres a gauge for the amount of power the car is making and it goes up to 1001bhp (this is because Bugatti wanted it to not only be able to get to 1000bhp, but also over it). It does 1250Nm of torque and is a permanent AWD.
Now if only I could find the 1million Euro's it'd set me back, my Volkswagon dealer will apparently bring one down for me, free of charge... how nice of em.
https://www.sau.com.au/forums/topic/37106-new-am-db9/#findComment-744047
Oh and have you seen Masserati's new Ferrari beating McLaren lookalike? Its called the Masserati MC12 Stradale.
Hmm right now i'm torn between a Rolls Royce Phantom, Rolls Royce 100EX, Bugatti Veyron or a Masserati MC12 Stradale...
/me gives up n goes back to his R32 GTS...
https://www.sau.com.au/forums/topic/37106-new-am-db9/#findComment-744048
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
