Hi all,
I recently just fitted my new engine in i had no problem's with abs or 4wd lights coming on. I have done about 5000km and now i have my abs light and 4wd light come on at the same time while im driving but its random. At times i can drive it for 10-15 km and it will not come on and then randomly it will appear. But sometimes i can start the car and it will appear as soon as i come out of my driveway. When the lights appear i can pull over turn the car off and on the light will disappear and it might not come on for another 10-15 km or it might come back on as soon as i start moving again. The car is a 1995 GTR r33 VSPEC it also runs motec if that can have some sought of play init????
Edited by sloppy
https://www.sau.com.au/forums/topic/371099-gtr-r33-v-spec-abs-4wd-lights-on/
My 32 does the same thing except the lights stay illuminated and I have to shut off the engine and start it again.
It is imperative that you are aware that while the lights are illuminated you have no abs and your 33 is running in RWD. I had an interesting moment in the wet but luckily I caught the rear end.
Some people would say g sensor is knackered, I haven't delved too deeply into fixing my problem as it is quite intermittent but it could be something as simple as your battery. There are a few threads regarding this subject on here, albeit when I fix mine I'll let you know what I did and hopefully we both don't have to spend 2 grand on a g sensor.
In the meantime, take your car to your trusted mechanic and have them run a diagnostics check on your hicas.
Hope this helps :)
