My first dream car needs to go! Prospect of moving to the US for work and being a home owner (soon to be two homes) I need the funds to be freed up for the time being.
LOTS of spare parts can be included in the sale as a package deal. Price is $27,900 and is negociable... if you like what you see make an offer.
Carsales ad can be seen here... here is a copy of the details. http://www.carpoint.com.au/all-cars/private/details.aspx?R=10921874&__Ntt=r33&__Qpb=1&__Dx=mode matchany&__Ns=pCar_PriceSort_Decimal|1||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&keywords=r33&__N=1216 1246 1247 1252 1282 4294963593 4294963846 901&__Ntx=mode matchallpartial&seot=1&__Ntk=CarAll&silo=1011&Cr=3&__Nne=15&trecs=67&__D=r33&__sid=1313757F270A
First owner in Australia purchased from Synergy Motorsports in 2008 and has been looked after and driven by meticulous owner. Unique ?Wine Red? colour and one of the only R33 GTR?s in Adelaide in this colour!
Serviced every 5000kms with the best oils; Redline gear oils in front, rear differentials and gearbox, Nissan Matic-D in transfer case and Motul 300V Chrono for engine. All work done by professionals.
Car is tuned personally by Brett West at Graham West Workshops, first R33 GTR in SA to have the top of the line Vipec V88 ECU (better than Motec) which has been fine-tuned since fitted for the best drivability and performance. ECU still uses OEM factory sensors, drives like a new car and very efficient with 500km (10-11L/100km) per full tank of BP98 (only ever run on BP98) and has a healthy 250kW (11psi) at all four wheels on 4WD dyno.
Over $15,000 spent over the last 3 years on modifications for reliability and drivability. List of modifications include the following:
- Bilstein PSS9 adjustable shock absorbers (kit alone over $4k)
- All OEM suspension bushes including subframe bushes (huge job!) replaced with polyurethane (Superpro)
- All ball joints replaced with OEM Nissan items
- All under-body components sand blasted, primed and painted black (2-pak)
- All bolts, fasters, washers, nuts re-plated (gold/zinc passivate... will last lifetime!)
- Upgraded swaybars (Whiteline)
- Upgraded NPC single plate clutch with billet machined chromoly flywheel; stock pedal feel, easy to drive but will never slip (less than 10,000kms)
- Kuhmo KU36 semi slick tyres (less than 15,000kms)
- Vipec V88 ECU tuned personally by Brett West, car gets run on dyno and checked every few months to ensure everything is ok
- Bosch 044 fuel pump mounted in tank controlled by Vipec V88 so at idle there is no noise from fuel pump
- Free flowing exhaust; stock exhaust also included in sale
Car is not defectable! Have had positive comments from Police officers on the originality of the car.
This is a real enthusiast?s car it has never been driven hard on the street, never been raced at the track and very well looked after. Suit someone who wants to buy their first GTR or a older buyer/collector and wants something comfortable and reliable. All modifications to the car have been done so to improve reliability and handling. There are cars in the same price bracket with more power but guaranteed they will not handle as good or will they be as reliable!
Body is great and is all original. Interior is brilliant for its age and is also all original and all electrics work perfectly.
A regretful sale as this was my first ?dream? car but time to move onto other things .Buyer will not be disappointed and car is priced to sell, slightly negotiable.
Many spare parts can be included in selling of the car i.e. as a package
- Engine block
- Cylinder head
- Nissan R34 GTR 6-speed Getrag gearbox with Nissan Motorsport twin plate clutch (combination good for 800hp)
- CWP gears for front and rear differentials; Brand new from Nissan!!!!!
- Rear mech. 2-way differential
- Front differential (with sump)
- Stock clutch and flywheel
- Heater core
- BOV piping
- Wiper motor
- Air-con compressor
- Turbo manifolds
- Wiring looms
- Steering column
- ... plus many other parts!!!!!
Edited by bigmikespec
https://www.sau.com.au/forums/topic/371178-r33-skyline-gtr-v-spec/
  • 8 months later...
Will also consider selling as complete rolling shell minus engine or minus engine and gearbox at a reduced price, contact via phone or PM.
Hard work has already been done to under body, bushings and top of the line Bilstein PSS9's. Big power forged engine can be dropped straight in for a street/track car!
Ok lads... after some feedback, what am I doing wrong? There has been little to no interest. This is a quality GTR here that has been looked after by a very fussy person (me) with a genuine reason for sale.
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
