Never heard of out, Forced performance do their own hta turbo with a similar name though which I don't know of anyone using on an rb but I recon it would be a good high power combo. I know someone with a 3586hta on an rb30 and it makes over 500kw on e30 with awesome delivery.
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-5917341
http://www.skylinesaustralia.com/forums/topic/251820-got-over-400kw-atw/page__hl__over+400kw__st__900
In this thread you will find results from 3788's, try to remember they are bolted onto big budget RB30DET's and not your average forged motor.
Considering there are 4088s and 4094s I have no doubt that garrett has simply mixed and matched some existing parts. IMHO I would expect the 3794 to be a little better under the pedal and make roughly the same power as the 4088. With the 3788 still being the pick of the bunch.
In the GTX thread I already told you to search and that if someone had one it would already be posted. Moving on..
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-5917415
They actually seem to push more than 4088rs in the cases I have seen, interestingly enough.
Yeah, power capability of approx the 4294 but the response of something like a T04Z
Only a turbo you would select for making easy 600hp at the wheels or pushed hard to 800hp at the wheels with the right fuel.
We use the 3788 as it's better suited to what we do/need
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-5917518
  • 9 months later...
For anyone that is interested, these seem to get less attention than the PT67 turbos but I've been a little more fascinated by these.... haven't said too much as I've been keeping an eye out for results on these things for AGES which are closer to indicating what to expect for those of us who don't want to have to rely on E85/huge boost for making good power and good spool - found that someone has run one on an XR6T and made really good power relative to boost level on one, despite being on a fairly basic setup with stock manifold etc. 400kw on 1bar on pump gas, for example... and sounds and spools awesome!
So now I'm pretty much convinced this would be a gun turbo for a big power RB that retains some form of streetability, they've made >900hp @ wheels on E85 (American dyno style, but still equates to >600kw @ wheels Dyno Dynamics if you take in account the differences) and pushed various Mitsis into the 8s.
See here:
And thread: http://www.fordxr6turbo.com/forum/topic/78068-boosted-1-in-with-446rwkw/page__p__1166770#entry1166770
Need to somehow fast track finding money to build an RB30DET suitable for such a setup :)
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6320960
  • 1 month later...
So, a 2litre EVO in the USA just put down 570awhp/425awkw on pump gas using a FP GT3794HTA (they did the 1.2 correction trick a lot of UK workshops do to estimate Dynojet/BHP type figures to get 684hp) - pretty impressive result all the same!
Mods:
· FF Shearer HTA3794 kit
· Magnus Intake w/ 65mm TB
· Buschur twin fuel pumps, ID2000 injectors
· Ported head, stock size valves and Kelford 280 cams
· 2.0 Liter Built
· Sparktech Pro CDI
· AEM EMS
Dyno plot:
Thread: http://forums.evolutionm.net/evo-dyno-tuning-results/616277-shop-fps-hta3794-combine-another-killer-pump-gas-combo.html
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6406068
So its 580rwhp with god knows what air temp, ramp rate or boost.
Cant be compared to anything....... Weigh the car..... run it down the strip.
If its 3000lbs and does 140+ then its about right.
Yeah im always suspect of DD graphs without te most important data visible. In fact we just did a test on a Mainline 4wd Dyno (new) and found quite a few variances in power outputs by changing very little 160rwkw first run r configure then run 200rwkw just by a few keystrokes...just to easy to fudge figures. Need to have the full story with dyno sheets.
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6407293
Fair enough, I'll keep the thread up to date with anymore info - its in the US and most people don't trust DD anyway so he is going to re-run it on a Dynojet. They sound like they expect it to do >140mph traps.
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6407476
^ yep, that and its running on a 2litre engine - life needs to make as easy as possible to make that kind of power.
Black bnr32, I'd love to see some dyno plots of EVOs making 420+awkw on a Dyno Dynamics dyno running straight 98 using a GT3582R.
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6407528
I always used to love DD because I think they give more realistic figures compared to hubbers, but after using the dynapac lots now I'm converted. The ability to have such repeatable and consistent results so you can actually compare cars and/or modification effects is awesome
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6407882
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
