Very cool indeed Nick. Looks very Lotus 2-Eleven-ish to me which is no bad thing.
Looks as though it would be a hoot to drive :thumbsup:
You have a Radical? What's your view on who might buy V2?
Prefer your missiles with some sort of control do you Terry ? Lol
To be honest that's exactly what I thought when I read it.
Car looks awesome mate, thumbs up to the builder.
Yeah, my mistake with the V2 thing. Just a name that came off the top of my head and not what it will be called. With bespoke and V2 I've not done that well on the naming front.......
Nah man, it's cool and it does evoke emotion.
the V2 rocket was the pinnacle of shit in it's day and they developer (Von Braun) was a genius, an amazing engineer, so much so that the yanks took him and his team to the states postwar when they were trying to steal all germany's technological advancements before the ruskies could.
Anyway, this is OT now Lol.
Ah gotcha - aside from switching the 13B for a 20B, I would keep it the same too :thumbsup:
If that's his plan for the car then the LS1/2/3 would be a safe bet. Are any of the new V8s from Ford all-alloy?
pretty sure the new coyote 5.0L supercharged v8 is all alloy.
how fast is it on the track?
Pretty fast mate. Don't wear your toupe when you're in it! I'm not sure it's done much track time as it's only done 5k klms most of which has been development work. I do know that with road tires and a passenger it did about 1.15 around Sandown on a sighting lap, so it's quick enough. Ultimately how quick I'm not sure.
It's an F3000 suspension set up with a 600-700hp/ton power to weight with a dog box so it's likely to be quick. I'd guess most hack drivers wouldn't get near its potential and let's face it that's what most of us are.
1.15 wow. i wonder what it could do with some decent slicks.
well, yeh, at those times a racing driver would make a difference however that's not to say you guys cant improve.
as they say, practice makes perfect.
I do indeed mate.
I think this sort of car would appeal to the same sort of customer base as an Ultima. I'd be looking at their sales rates and trying to go from there. Has your friend put it on display anywhere as yet? Something like the Top Gear Live show or similar could garner a good response. Radical did that at the last one, and we had a test day out at Winton a few months back with potential customers able to go out as passenegers in the car.
http://dbsmotorsport.wordpress.com/2011/06/24/winton-test-31062011/
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
