So I'm sure a stack of people will already know about Upgarage and all that jazz, but I recently did a write up on my blog which I thought would help some people out on here too, so enjoy.
How to: Search on Up garage + Shipping parts from Japan
Sick of paying premium for JDM parts locally? Can’t find what your looking for on Yahoo auctions? Or, don’t know how to get that part to your door? It’s all in here!
There is an alternative to Yahoo auctions called Up garage, which is quite easy to use and is based around cars/bikes. I’ve found quite a bit of cool gear on Up garage for both the MX-5 and Stagea, at great prices.
To get started, click this link. It’ll take you to Up garage home page. Underneath the header you’ll notice two big boxes, on the left is the Car category and on the right is the bike category.
Inside those boxes are two smaller boxes, one is for listing an item on Up garage, and the other is for searching. So click on that right box. You will be now taken to a new page (bookmark this page, it skips the first step).
Now you are on the lookout for the search bar, it’s mid page towards the left. Look at the above picture for reference. When entering in your search, the characters must be Japanese! unless you are entering model codes, i.e Mazda MX-5 = NA6CE, NA8CE, NB8C and so on.
You do not need to be precise with searching model codes, for example instead of ECR33, you can just use R33 to broaden the search. Once you are ready to begin the search, click the button on the right of the bar, or hit enter.
A search will come up with many cool parts for your car, but we aren’t done yet! If one of many parts interest you on Up garage, you can click on the listing to get bigger photos, and a description of the goods as shown below.
So your set on getting a certain part for your car, now what you can do is contact either Jesse Streeter (www.jessestreeter.com), or Rod from Tetsuya Garage (www.tetsuyagarage.com) to get a shipping quote. They will organise everything from purchasing off the Up garage vendor, to getting the goods to your door in as little time as possible.
Another handy tip is to use a translator, it makes things a little bit easier and quicker. I use Microsoft Translator when I get stuck. The great thing about Microsoft Translator is that it can translate the whole web-page you want to view.
So there you have it guys and girls, I hope this makes shopping for parts in Japan a little bit easier for everyone.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
