Hi guys just an update
Came back from the workshop and he said that it was likely the actuator on the turbo that is stuffed overboosting the turbo causing it to whistle.
I advised him at first that it maybe the gasket between the manifold and Turbo so he opened the bonnet and reved it. He said if it was a leak he would have heard it.
So we then went for a spin and at times the boost would spike to around 13-14 psi and make that whistling noise. When the boost only when to 10 psi it wouldnt.
So his diagnosis was that since he had removed the boost controller and put the stock bits in and it was overboosting that it is probably the actuator that is stuffed causing the turbo to overboost and make that noise.
Opinions please? Sounds plausible? Should I get another workshop to look at it before I decide to shell out for a new turbo.'as he said I just may as well buy a new turbo.
Any help much appreciated :)
I would say hes probably telling you the truth. I've unfortunately got an exhaust leak from my rear turbo and the sound doesn't come or go, it's always there. You can hear the 'airy' sound on decel and it runs like a bucket of shit. Have him finish of his work and before you pay the bill ask him to come for a quick lap to see if it's still doing it.
I doubt you need a new turbo.. more like the actuator hasnt been put on properly or you have a leaking hose, why not get in there yourself and eliminate all these possible causes, source a second hand acutator and try it yourself
i leaking hose would give you overboost, cost to replace =zip
get a bright light in there and look for any soot gather around the gaskets which = leaking gasket
make sure you dont have some garrett highflow, i never knew myself until i was told,
you dont have a cheap split dump pipe do you?
Just an update guys!
So after 2 weeks of being told the noise is my boost controller, then my turbo , then my actuator and dismissing that it can't posssibly be the gasket between the turbo and manifold, I dropped off the car to Rob at Sabbiddin Automotive to get the car checked out. I've had my car for their for mechanical work in the past and respect his professionalism.
I just received a call from Rob just then and hey prestoooo...It's the gasket between the turbo and manifold, and that there's a bit of shoddy work from the previous work :rolleyes:
Regardless I'll be eventually getting a new turbo soon, but didn't appreciate the advice from the previous workshop even after telling him what was the problem.
So just a shout out to everyone that helped and especially Daniel from Elite Racing :cheers:
I won't publicly name the workshop as that isn't appropriate & allowed and to a certain extent everyone makes mistakes, but I will say this workshop is in the South-eastern suburbs of Melbourne and is a workshop referred onto by one of the top Tuners in Melbourne that is regarded on this forum.
:thanks: to the SAU Community :action-smiley-069:
Glad to help. It's good that you found someone to sort it out for you. I was going to suggest someone when you asked but thought again about it. I was absolutely certain it was going to be that gasket so it is a good thing you persisted with it or you end up like every other poor bastard around.....even poorer and still without a fixed car.
Rule #2 is: If it smells like shit, feels like shit and tastes like shit....it's most likely not going to be a cheese sandwich
Thanks guys :cheers:
Just picked up the car and it feels great again. Rob said some bolts were missing, some bolts not tight, hoses weren't in properly ahhh i just had to laugh.
Now its time to save up for some ID 1000 injectors and a Hypgear turbo :thumbsup:
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
