hey guys, fellow member said i should write up a tutorial so i will
i bought myself some DTM Rush wheels that were oddly coloured, so i decided to paint them!
what you need
-primer
-sand paper grit really depends how much crap you want to take off. i just used the one pictured as the surface was pretty good.
- masking tape
-PAINT!
-clear!
now the paint and clear can come in rattle cans and if you take your sweet time, they will come up looking great!
Step 1
wash the wheels, dry and sand away!
should look like.. err sanded wheels..
now some of the wheels had some chips which i just filled with some filler and sanded down. unfortunately i didnt take pics of this step.
Step 2
wash the rim again and wipe it down with some turps
them, PRIMER TIME!
allow to dry and if everything looks the goods, (no running, no imperfections) move onto step 3!
Step 3
TIME2PAINT!
using the colour of your choice, (i used metalic cyan :) ) spray the wheel, i started with the barrels first and then moved onto the spokes. doing even sweeps with the spray leaving a nice even finish (though i did add a little too much in areas but hey its my first time!)
i added another 2 coats per rim. went through about 3 cans.
Step 4
left to dry for a couple hours i came back and started on the clear coat!
pretty much the same as the paint. did 3 coats too
Step 5
kick back and wait!
should look something like this
Hope this helps. all the stuff was bought from super cheap auto. each rim took me about half an hour to prep.
Cheers!
https://www.sau.com.au/forums/topic/371218-how-to-paint-your-wheels/
no worries. forgot to add, tape up the valves of course
and when dry. tape the lips so you wont chip the paint while putting on tires
or you could simply just break the bead and leave the tyre on the rim but you would be able to spray all of the lip since the tyre wouldn't be touching it.
Mighty car mods just posted video on painting rims :P
haha yeh jonno was telling me when i was doing mine
that could be done too.
nice green badge kent
  • 5 months later...
i must be honest they look great , i wonder if the paint/prep used by crash repairs will provide a harder longer wearing surface ?
Yeah 2 pack paint will dry harder is less prone to chipping and especially peeling when replacing tyres etc. Other than that great work man really good looking result. Next time get some red scotchbrite to get into all the little corners where you cant reach with sandpaper to scuff the surface right up before primer which will make them less likely to peel in those areas.
Ok probs going to sound like a stupid question but how do you remove the tyres from the rims and how do you get them back on... i know a bit of a noob question.
you need to "break the bead", which is usually done with a press (if you have access to a welder you can make one, or you can even make one out of wood, but it won't work as well and may break). then it's a case of using tyre levers to get them off. it's not that hard. then you use tyre levers and a rubber mallet to get them back on, but you run the risk of scratching the rims.
or you can pay a tyre shop to do it.
Good write up and fantastic result, well done.
If you get a bit of orange peel from the clear coat - etc, or between layers - you can sand it back with 1200 then 2000 grit wet and dry to smooth it out.
With the clear, if following the above step - you can then buff it up to a magic shine afterwards.
  • 3 weeks later...
Im assuming this is best done with tyres off, but are there any magic taping tricks i could use to cover the tyres or will it be easier and better if i do involve taking the tyres off
I'm about to do my Works XT7's and am not only taking the tyres off but will be removing the valves too so we can spray the whole rim.... There is no reason you cant tape them up but if its a skyline then tyre changes should be as regular as fuel stops so just do it then :laugh:
Touche, im yet to wear them in yet though :P so ill wait till thats done, and by then Ill know if I really want to paint them
good write up and they look good for now but unfortunatly uve used a cheap enamel and will look like crap in no time.i would recommend to anyone else doing this to use a 2 pak paint for a better finish and longer lasting results :thumbsup:
i was looking into getting mine Powder coated, Costs about $450 but i heard much much less likley to chip.
After seeing this though im going to grab my self some paint this weekend, Did you look into hiring a sand blaster? or getting them blasted first?
Not sure how good it will all stick to the existing paint, Or is the idea of the sand paper to leave it rough for the primer to grab hold?
Is ther much choice on clear coats? a more resitant one for stone ships ect.
By any chance did you see if they had a satin or semi gloss black?
  • 3 weeks later...
sand paper leaves it rough, i finished in a 600 grit paper wet and dry sanding
then etch primer with a proper gun and compressor
then used semi gloss black to spray my corolla rims
no clear coat
in perfect condition hasnt chipped at all.
cost me about 100 bucks in total
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
