i was looking into getting mine Powder coated, Costs about $450 but i heard much much less likley to chip.
After seeing this though im going to grab my self some paint this weekend, Did you look into hiring a sand blaster? or getting them blasted first?
Not sure how good it will all stick to the existing paint, Or is the idea of the sand paper to leave it rough for the primer to grab hold?
Is ther much choice on clear coats? a more resitant one for stone ships ect.
By any chance did you see if they had a satin or semi gloss black?
Brother i got my BBS RS wheels powdercoated from Pass Powdercoating in Marayong for a total fee of $160, all 4 Rims and 4 waffle centre plates and they looked magic, all i did was remove the front lip because they are a 3 peice rim, but this is a 1 peice rim so i wuddnt see it being much different ay.
ill tell u how good the quality was i actually threw one of the waffle plates down the backyard like a frisby in anger from something going on and they smashed into the back fence and hit the concreate and there was no damage what so ever.
Edited by sultanaz
sydking
just to give you a idea.
when i bought the bbs rs wheels...
  • I broke the rims down in 3 peices (3 peice rim)
  • sanded the lips all back to remove corrosion and polished up afterwards
  • i cleaned up the bolts & nuts
  • sent the rims to be powdercoated
  • bought new centre caps and hexnuts
  • recieved the rims back and started putting it back together
  • sealed up all the rims again and torque'd every bolt to the same tension
Alot of stuffing around, but hey look at this
and then the after shot
cheaaa :D powdercoats the shit !!!
Edited by sultanaz
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
