Hi all,
I have for sale our Ford EF XR8. We have had the car for a bit over a year now and was bought mainly for towing my car.
However since we bought it I have only used it once for towing and really have no need for the car anymore (having 4 cars already)
So here is the run down:
FORD EF 1996 XR8 AUTO
White
203,000kms
12 months rego
4 new tyres
New front and rear slotted rotors
New front pads
CD
Air
Power front windows
Power mirrors
Tow bar
Aftermarket headers
Twin stainless exhaust
Since we bought it the following has been replaced in services:
Top rad hose
New leads
Plugs
Battery
Rotor button
Ignition module
CAS
Fuel filter
Also had the front bar professionally repainted.
Has a minor scratch and a slight ding above the rear wheels arch but the paint is in very good condition for its age.
The gearbox looks to have been re-done at one stage by the previous owner as it is remarkably clean.
There is one slight bad point, when cold it will sometimes take a bit to engage 1st but happens only once then it's fine.
Price is $5500 ono.
Pics up soon but interested people can send me a PM for quicker pics.
https://www.sau.com.au/forums/topic/371239-fs-ford-ef-xr8/
  • 1 month later...
  • 4 weeks later...
$3300 THE LOWEST I WILL GO!
Has to sell this month otherwise its off to a used car dealer. Grab a bargain!
Dont ask for pics, if you are interested in buying the car come and have a look at it.
https://www.sau.com.au/forums/topic/371239-fs-ford-ef-xr8/#findComment-6100116
  • 3 weeks later...
    • Hi Everyone, I did 4.11 gears in my 34 GTR and only thing that remains is to fix the speedo reading (it reads about 15% higher) using the R33 GTR speedo sensor. Few questions:   1. Does the R33 speedo sensor fit right in to the 6sp getrag? I read it does but wanted to confirm because the speedo sensors between 33 and 34 look quite different   2. The connector on the 33 speedo sensor will not plug into the connector on the getrag. Do I just need to wire the pins together manually?  See pic: https://imgur.com/a/NTDzFe8
    • Does anyone know how I could find the part number for bolts used with  r34 with rb25detneo engine lower timing belt cover?   my timing cover was rubbed and i fixed it but upon putting the harmonic balancer i see the timing cover is almost rubbing and that is due to previous owners using general bolts and washer rather than the bolts per link below which sits inside the washer and pull the cover in   not sure if those bolts will fit rb25   https://www.ebay.co.uk/itm/326510870741?gad_source=1&gbraid=0AAAAAB_7XZxjuciMybdVOTShCs9857686&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338723872&toolid=20006&customid=7jIl12glAAAAVfHSSnyxAmSsdRxnAAAAAA
    • If the slightly higher internal EGR caused by a high flow cat causes detonation your tuner was way, way, way too aggressive to begin with. Timing scatter is a problem unless you go to a crank trigger, winter vs summer blend has different octane, list goes on.
    • The H1 Alpha with the 6.6 Duramax is basically the actual powerplant it needs to be remotely ok to drive on public roads. It's just not worth the cost to buy a real one. Humvees look cool but man the reality of them is depressing. Grunts aren't kind to them but they aren't that reliable either, they have horrible payload despite absolutely massive size, zero actual armor against mines/small arms, absolutely anemic naturally aspirated diesels, list goes on.
